69' Fuel system replacement - Chevelle Tech
post #1 of 7 (permalink) Old Apr 14th, 14, 10:43 AM Thread Starter
Doug
All,
I have a 69' Chevelle with a MJ 468 in it. I'm going with a mechanical fuel pump and already have the 3/8" fuel line run. I am looking to replace the fuel tank and sending unit as well. My questions:
Do I need to go with the 2 vent fuel tank, 2 line sending unit, and non vent cap that is year specific to the 69's?
Since I am building this from the frame up, is there a better option?
Can I run a 70' fuel tank with a vented cap and one line sending unit? I believe those didn't have the fuel tank vents that the 69' had?
I have read through a ton of threads on here and can't seem to find the answer to the questions above.
Thanks for your help.
Doug
hdw1679 is offline
post #2 of 7 (permalink) Old Apr 14th, 14, 12:46 PM
Re: 69' Fuel system replacement
Bag the mechanical fuel pump and put a electric pump on that will keep up to your engine and fuel uses. Tap the fuel pump into the oil pressure electric circuit, so that if you lose oil pressure for some reason, the fuel pump will kill the engine. If you go with the return line, put a chiller on the fuel line if you are dragging the car, otherwise, use a fuel tank with a sump in it to always have fuel to pickup and feed the engine (especially if if you are using the car for pro touring).
70SS454 is offline
post #3 of 7 (permalink) Old Apr 14th, 14, 1:58 PM Thread Starter
Doug
Ok thanks for the info. I guess I should add that this will be a 99% street car that will be used mostly to cruise in. I obviously want to avoid starving it for fuel but am looking for the best set up to not break the bank and avoid any fuel issues.
Thanks.
Doug
hdw1679 is offline
post #4 of 7 (permalink) Old Apr 14th, 14, 2:24 PM
I don't have an opinion on which tank would work better, but as long as the tank is vented properly and you have a good quality mechanical pump, it should work fine.
69 Chevelle 496/TH400
ET/Speed - 11.371 @ 117.23 - SOLD JUNE 2017
1965 Chevy Impala 355/TH350 - NEW RIDE JUNE 2017
Georgia69 is offline
post #5 of 7 (permalink) Old Apr 14th, 14, 4:25 PM
Thanks.
Doug
Doug, in that case I would have left it a 327/350 cu.in. and left the money in my jeans. A 468 is strictly for bragging, not cruising. Something tells me your going to step on this engine eventually and that's why you asked the question.
You may want to look at the vacuum in this 468 because I'm sure you'll want to stop it at some point and your brakes are going to need some.
Good luck.
70SS454 is offline
post #6 of 7 (permalink) Old Apr 14th, 14, 7:10 PM Thread Starter
Doug
Haha I Didn't say it wasn't going to get floored every now and then! It's just being built to cruise in. I'm just looking for something that works well and that is relatively simple. Appreciate your help though!
Doug
hdw1679 is offline
post #7 of 7 (permalink) Old Apr 15th, 14, 8:37 AM
Mark
If I could do it again with what's available today, I'd go with a stock style tank and the aeromotive in-tank electric pump with a return. I'd also make sure all the lines from the tank to the front are stainless or Teflon lined. The fuels today do some funky things to rubber and also can cause vapor lock issues for carbs. If funds allow, I'd go stainless for the tank or at least treat it with something like the Eastwood stuff before putting gas in it.
If you change the lines, I'd also recommend running 8AN to a regulator and 6AN to the carb. This may be a little overkill but could be helpful if you upgrade anything in the future.
MadmanMark is offline
This Thread is more than 1951 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
