How to tell 3/8 fuel line from 5/16? - Chevelle Tech
post #1 of 9 (permalink) Old Jul 17th, 06, 8:57 PM Thread Starter
I'm trying to determine if my car has a 3/8 or a 5/16 fuel line since to me they look relatively close.
What exactly do you look for? Inner diameter or outter?
It's a '71 Chevelle that came factory with a 350 2bbl if that helps any.
'71 Malibu 402 big block/TH350 trans - Sold 2 Jan '08
How to tell if your car is a true SS or not:
Junkyard Dawg is offline
post #2 of 9 (permalink) Old Jul 17th, 06, 9:03 PM
Chevelle Doctor
Re: How to tell 3/8 fuel line from 5/16?
You're measuring the outer diameter. A 350 2bbl car will probably have a 5/16" fuel line. To measure for sure, take an open end wrench and try to slide the open end over the tube. This will be very close.
Authentication and pre-purchase inspection service still available. PM me for more information.
Still looking for that elusive 76 Nova SS.
People who have nothing better to do than b!tch about signatures need to get a life.
70 Chevelle L78/M21
10 Avalanche LT 1500 4wd
06 Equinox
Dave Birdwell is offline
post #3 of 9 (permalink) Old Jul 17th, 06, 10:06 PM
Tubing is OD (outside diameter) and Pipe is ID (inside diameter). So the easiest way to tell the size of your fuel line, which is tubing, is to use a combination wrench. Whichever one slips over snuggly is the winner.
66 327 Malibu RIP
86 Cutlass
94 Cadillac STS
ME LaZerte Mechanics Teacher
wanarace is offline
post #4 of 9 (permalink) Old Jul 17th, 06, 10:58 PM Thread Starter
Thanx....looks like mine is 3/8. I couldn't even get a 5/16 wrench to fit it.
post #5 of 9 (permalink) Old Jul 18th, 06, 10:56 AM
Depends if you're a plumber or a refrigeration tech.
I never understood why WE plumbers call 5/8" o.d. copper 1/2" & 7/8" o.d. copper 3/4" etc while WE refrigeration techs call 5/8" o.d. 5/8" and 7/8" o.d. 7/8" etc. One old plumber said "we don't care about the outside, we are only concerned about what goes through the inside" but I think we just want to confuse people.
I understand why pipe doesn't really measure what it's called (1/2" pipe is not really 1/2" on the inside but "half inch" is "in name only")
At one time the I.D. of iron pipe did measure correctly but as years passed better materials and better methods allowed iron pipe to have a much thinner wall thickness and since all the thread dies sizes were SET, the material had to be taken from the inside.
Sorry for getting off topic, I agree an open end wrench is the quickest way to idntify the outside diameter of tubing.
post #6 of 9 (permalink) Old Jul 18th, 06, 11:41 AM
Dean, You think plumbers have confusing dimensions. Try the woodworking business.
How wide is a 1x6.. Answer: 3/4 x 5&1/2. etc.. Overseas plywoods (Baltic birch, for making drawers) come in 5ft x 5ft sizes so you can no longer fit them into the back of the pick-up with the cap on. Then there/s the hardware mostly measured in millimeters. We have 35 MM hinges, we have all the drawer slides in metric. The list goes on.
Bill Rose is offline
post #7 of 9 (permalink) Old Jul 18th, 06, 2:54 PM
My house was built in 1939. The studs in my garage are real 2 x 4 measuring 2" x 4." Kinda neat, until I wanted to hand a ladder from the rafters, and found that the rafter hangers in the hardware store are sized for modern lumber and too narrow. I had to fabribate my hangers our of bar stock.
As far as gas line goes, if I go by the OD measurement, how can I be sure the ID will fit the fitting? Can I trust the hose manufacturer to use a standard wall thickness?
Isn't hardware fun?
Burbank SS is offline
post #8 of 9 (permalink) Old Jul 18th, 06, 4:38 PM
If you have access to a pair of calipers, 5/16 = .3125 & 3/8 = .375
Cheers,
Garry
My 69 Triple Black SS
95 Harley FLHR
Gazzer is offline
post #9 of 9 (permalink) Old Jul 18th, 06, 8:49 PM
On the same off-topic: Not too long ago, I learned that a certain gauge sheet metal can come in different thicknesses, depending on which metal it's made of. And why is 1 foot = 12 inches, 1 yard = 3 feet and 1 mile = 1760 yards, when the numerical system we all use is based on 10? Just gotta love the so-called "standard" system. Have I ever mentioned the advantages of the metric system?
1969 Malibu in progress
Olle is offline
This Thread is more than 4949 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
12.0 on a 5/16th fuel line... Astro70SS 2006 10 Apr 3rd, 06 3:04 PM
Fuel pump to carb line (pics) cmeyss 2005 12 Mar 30th, 05 5:51 PM
I think I lost some hp somewhere...any suggestions???? LXS 2004 11 Jul 8th, 04 7:05 PM
BB/SB Fuel line measurement? 70ECam Restoration Corner 1 Apr 24th, 04 12:44 AM
67 396/350hp Fuel Line 67SS4speed 2000 8 Jul 7th, 00 2:43 PM
