Interchangeable parts for 1968 Chevelle - Chevelle Tech
 2Likes
  • 1 Post By Ericnova72
  • 1 Post By Ace141
post #1 of 15 (permalink) Old Jul 31st, 20, 6:37 PM Thread Starter
Hello! I am new here and have been searching everywhere to find out which parts are interchangeable between a 1968 Malibu Hardtop and a 1968 300 Deluxe pillar car. We are about to start restoring the Malibu and would like to use as many parts as possible from the 300 Deluxe if things are interchangeable. If anyone can point me in the right direction or give me some advice it would be greatly appreciated! 😊
Ace141 is offline
post #2 of 15 (permalink) Old Jul 31st, 20, 9:53 PM
Terry
Re: Interchangeable parts for 1968 Chevelle
Steering wheel is 300 Deluxe specific, as well as rocker moldings, eyebrow moldings on fenders, rear bumper, door panels, rubber flooring. Most other parts are the same as Malibu. Terry
68-13427 is offline
post #3 of 15 (permalink) Old Aug 1st, 20, 12:30 AM Thread Starter
Thank you Terry! I was trying to find out if the door windows are the same too, I think I found that the vent window will work, and I know the quarter window won’t work
Ace141 is offline
post #4 of 15 (permalink) Old Aug 1st, 20, 3:29 AM
Anything specific to the pillared sedan roofline and doors won't interchange...door, door glass, wing vent, rear quarter window, door weatherstrip are all different.....this as all due to the door having a frame around the glass, rather than a hardtop where the glass seals to the body at the top and the hardtop glass trim w/rubber at the back edge, that is attached to the rear quarter window.
Door shell itself is more than likely interchangeable, once you cut the side glass frame off, might require a little hand rework where the glass comes out through the top of the door skin. window regulator parts are likely different.
Just about everything else on the car will interchange....there may be some minor style differences in trim levels, but it will all bolt up.....entire front clip from firewall forward, entire back half of the car except rear quarter glass and sedan pillar., just about everything interior trim and dash, including seats and headliner and front/back glass.
68-13427 likes this.
Ericnova72 is offline
post #5 of 15 (permalink) Old Aug 1st, 20, 8:41 AM
So you are parting out a '68 300 2-door sedan?.....
Been looking for one of those for a while now to build into an L79 car.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #6 of 15 (permalink) Old Aug 1st, 20, 11:48 AM Thread Starter
Thank you so much for all of the information! I have spent so much time searching and couldn’t find much information about it online. Augy our 300 deluxe has a ton of rust, there are holes in the floor and the doors so that why we are using that one as the parts car. We are located in Saskatchewan, Canada so the extra stuff we can’t use will be available once we are done 😊
Ace141 is offline
post #7 of 15 (permalink) Old Aug 2nd, 20, 12:30 PM
Just curious, where in Saskatchewan?
augy is offline
post #8 of 15 (permalink) Old Aug 2nd, 20, 3:06 PM
Vince
looks like just North of you...
VinceS427bb is offline
post #9 of 15 (permalink) Old Aug 3rd, 20, 8:23 AM
Hey, you're right.....
Actually looking for name of city he's from in Saskatchewan, which is kinda north of MN.
augy is offline
post #10 of 15 (permalink) Old Aug 3rd, 20, 3:54 PM Thread Starter
Sorry I didn’t see that you were replying until now. Saskatchewan is a province in Canada so we live in the northern part 😊
Ace141 is offline
post #11 of 15 (permalink) Old Aug 3rd, 20, 3:56 PM Thread Starter
I was going to ask as well, does anybody know if we could use the glass from a 1969 chevelle for the doors on a 68 Malibu? I like the looks of the full glass better then having the vent window
Ace141 is offline
post #12 of 15 (permalink) Old Aug 3rd, 20, 6:14 PM
Ace,
One additional thing to be aware of.
The tail light housings, tail light lenses and rear bumpers are TOTALLY different between Malibu and 300 models.
The Malibu and 300 tail housings are completely different because thay have different light bulb sockets and lenses.
The Malibu tail light lens is full length. Thus, just ONE light bulb and socket.
The red portion of the 300 tail light lens is shorter because the backup light socket and bulb are in a second hole in the housing and the backup lens is adjacent to the red lens.
That's why the housings and lenses are completely different.
The rear bumpers are different, because the Malibu bumper has two rectangle openings for backup lights.
The 300 bumper does not have the openings for backup lights, because they are incorporated in the tail light housings.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #13 of 15 (permalink) Old Aug 3rd, 20, 7:42 PM
I went the other way, '68 wing vent and parts into '69 doors many years ago, from what I remember it was just adding a couple screw holes, the door frame and skin was the same shape.
You may have to check and add some window trim holes where the vent wing was, for the outer window felt trim strips
Basically comes down to pull the inner door panel off, and inspect for differences....may not work putting newer year stuff in older doors but I know it works putting older stuff in newer doors.
I did the same thing with a '72 Nova, I used a full glass '74 door shell and transferred the wing vent and glass hardware and window regulator over from the '72 door into the '74 door and put it on my '72 Nova.
post #14 of 15 (permalink) Old Aug 4th, 20, 4:31 AM Thread Starter
Thank you DZauto! We actually have a good bumper and tail lights from the Malibu so we won’t have to switch them but thanks for the info!
Ace141 is offline
post #15 of 15 (permalink) Old Aug 4th, 20, 4:34 AM Thread Starter
Ericnova72 we ended up taking a look at the doors today now that everything has been removed and after looking at the way they are built I don’t think we will be able to go with the full window since towards the front of the door there is a metal brace where the vent window would be. Not sure if we could cut it out or would have to switch to a 69 door instead
Ace141 is offline
