1966 Vent Window knob screw - Chevelle Tech
  • 1 Post By 67ss4spd
post #1 of 6 (permalink) Old Jul 1st, 20, 3:54 PM Thread Starter
The knob on my vent window is loose and I'm trying to figure out the screw that holds the knob on the shaft. Can someone tell me if it is a allen wrench and if so, what size? If it is a screw, phillips or straight? I just can't see in the hole what is holding it on.
Jerry Coia is offline
post #2 of 6 (permalink) Old Jul 1st, 20, 6:28 PM
It’s a roll pin.
67ss4spd is offline
post #3 of 6 (permalink) Old Jul 4th, 20, 1:12 PM Thread Starter
Re: 1966 Vent Window knob screw
I don't see an exit hole on the other end of the knob. How do I remove this pin or tighten the knob?
post #4 of 6 (permalink) Old Jul 4th, 20, 1:42 PM
Mark
Hi Jerry, look on the inside of knob (glass side) you will see the hole. Here are a couple of pics. I didn’t have a pin at the time I found a small nail and cut to fit. Hope this works for you.
Mark
ID:	631994   Click image for larger version
AZMARK is offline
post #5 of 6 (permalink) Old Jul 4th, 20, 2:00 PM
With the knob in closed / locked position there’s a small hole on top. Drive it down and out from that end. Use a 3/4”-1” long - 1/16” diameter punch. Depending on who may have opened it before, there will be a couple wave washers sitting on the stud. The nut on the glass removes the clad stud. There is an offset plastic spacer in the glass that’s probably pretty fragile so be careful with that. The stainless cladding will polish up nice with 2500 / 3000 grit. Put a dab of white grease on everything when assembling so it all threads together and moves freely.
ID:	632000   Click image for larger version
ID:	632002   Click image for larger version
LeoP likes this.
67ss4spd is offline
post #6 of 6 (permalink) Old Jul 4th, 20, 10:08 PM Thread Starter
Thanks for the advice and the pictures! I'll work on these when I get the new ones in.
Jerry
