Good alternative to hose clamp to mount tach on column? - Chevelle Tech
 10Likes
  • 2 Post By 69SS454
  • 5 Post By 65cayne
  • 1 Post By shovelrick
  • 2 Post By hydro462
post #1 of 13 (permalink) Old May 9th, 20, 9:40 PM Thread Starter
Rich
I have a very cool old vintage tach I want to install in the wagon. I plan to put it on the column and I'd like to mount it with something a tad more attractive than a hose clamp. I need a clamp able to encompass about 2"-2-1/8" given where I want to mount it. Any ideas?
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #2 of 13 (permalink) Old May 9th, 20, 10:01 PM
Re: Good alternative to hose clamp to mount tach on column
I used to have a tach mounted on the small end of a piston connecting rod and the big end clamped on the column. I welded a nut inside the small end of the rod. The tach was bolted thru the back of the gauge cup.
Blown1932 and hydro462 like this.
69SS454 is offline
post #3 of 13 (permalink) Old May 9th, 20, 10:06 PM
Iíve used a screw through the bracket into the column. No hose clamp.
67
70 (SOLD)
Alwhite00 is online now
post #4 of 13 (permalink) Old May 9th, 20, 10:16 PM Thread Starter
Rich
Yeah, not drilling any holes in my tach mount and especially not in my original 4-speed column jacket.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #5 of 13 (permalink) Old May 10th, 20, 3:52 AM
Re: Good alternative to hose clamp to mount tach on column?
I put black shrink tubing over the hose clamp and heated/shrank it to conform to the band. Looks nice(r) and wont scratch your column.
-Kevin
1965 Chevy Biscayne
<removed> 454cid, "peanut ports", Voodoo 60201
<coming soon> 460cid, Brodix RRO 270, 229/241 Hydraulic Roller
TH400, 3.36 Stock Rearend
65cayne is offline
post #6 of 13 (permalink) Old May 10th, 20, 11:47 PM
agree..you can wrap it. I used one of the screws already in the dash and stuck it just under the pad dashpad no hoseclamp needed. i cant post pics on here but can email you one.
cuisinartvette is offline
post #7 of 13 (permalink) Old May 11th, 20, 7:03 AM
Rame
What about some high quality double sided tape? It's pretty strong, and you can remove it with solvents if you ever want to take it off.
sampoerna415 is offline
post #8 of 13 (permalink) Old May 11th, 20, 8:48 AM
rick
36" black cable tie? but I also have a tool to tighten them
hydro462 likes this.
shovelrick is offline
post #9 of 13 (permalink) Old May 11th, 20, 8:53 AM
Shane
Google "column tach mount"
There are plenty of cool options.
fishhead is offline
post #10 of 13 (permalink) Old May 11th, 20, 9:37 AM Thread Starter
Rich
This is probably the best quick and easy solution.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #11 of 13 (permalink) Old May 11th, 20, 10:13 AM
Hide a shift light under the dash and have it shine against the windshield through the defroster vent..
vortec710 and kermitsass like this.
hydro462 is offline
post #12 of 13 (permalink) Old May 12th, 20, 1:07 AM
I vote for the shrink wrap plan. cheap too.
post #13 of 13 (permalink) Old May 12th, 20, 11:12 AM
Bruce
Any ideas?
Please have a look at my "Garage." There's a photo in there of my "cool old tach" that I mounted "upside down" to the underside of the dash top.
I used a kit I bought off eBay that consists of two strips of metal strap and two strips of rubber. The kit sandwiched the tach's base to the plastic instrument carrier at a screw hole, I added a second screw hole for the other end of the straps.
It's a very simple, very nice, very clean mounting. PM me if you want additional pictures of the setup.
Our You Tube Vids:
NickeyChevelle is online now
