Barrel (Inverted Flare)nuts for hard brake lines - Page 2 - Chevelle Tech
 14Likes
post #16 of 18 (permalink) Old Mar 31st, 20, 6:36 AM
Re: Barrel (Inverted Flare)nuts for hard brake lines
Calling inverted flare nuts "barrel nuts" ?
Originally Posted by LevonH View Post
Edited title.
Yeah, that title completely confused me. I thought there was something wrong. Thanks guys.
BillyGman is offline
post #17 of 18 (permalink) Old Mar 31st, 20, 7:49 AM
Originally Posted by OC66 View Post
Hey everyone hope you're all doing well in these times right now. I went to install new hard brake lines on a new rearend for my 66 Chevelle this morning. I bought new 3/16" brake lines and when I went to thread the the new line to the caliper the barrel fitting on the new brake line is a bigger size than the original 1/8"-27npt that the car has. Does anyone know where you can buy just the barrel/ tube nuts anywhere? I looked on Summit and Jegs with no luck. I'm putting a Strange S60 rearend with Wilwood disc brakes. Any help would be greatly appreciated thanks and be safe 👍🇺🇸👍
It would help to know which Wilwood disc brakes are installed on your S60. Many of the better Wilwood kits have 1/8"-27 NPT threads in the calipers which you have to install an adapter fitting (1/8"-27 NPT male to -3AN male for example) in the caliper, a short -03AN female to -03AN female flexible hose and a Brake Adapter Fitting SAE female 3/8"x 24 to -03AN male connected to your male 38"-24 3/16" brake line fitting. Here is a photo of what I did on a 1965 12-bolt Chevelle rear back in 2004 (removed in 2017) as an example. You can run the hard lines directly to the calipers provided they are fixed (rigid mounted) and not the floating ones but the installation I have done with the flex lines just makes the installation a bit easier to work the lines around the rear shocks. Never had any fluid leaks on this rear setup.
ID:	621286   Click image for larger version
USAF Retired (1968-1988)
David Bates is offline
post #18 of 18 (permalink) Old Mar 31st, 20, 10:10 AM Thread Starter
Yes I called Wilwood and they said there is a adapter that goes from a male 1/8-27npt to a female 3/8-24. Also a friend of mine has the same Wilwood brakes on his 67 Nova and he sent me a picture and his has the adapter fitting from the caliper to the line. Like I said only thing I can think of is the new lines I bought had a different size fitting cause they were bubble flare for a newer car
OC66 is offline
