194 led lamps - Chevelle Tech
 7Likes
post #1 of 29 (permalink) Old Mar 26th, 20, 2:46 PM Thread Starter
Todd
194 led lamps
I am thinking on trying 194 led for the dash cluster. I am not sure if it will affect the resistance. Has anyone tried led 194s and how did it work out?
Thanks,Todd
tday815518 is offline
post #2 of 29 (permalink) Old Mar 26th, 20, 2:54 PM
Al
Re: 194 led lamps
For dash illumination, you won't have an issue with resistance. Most are polarity dependant. So if they don't work one way, flip them and they should work. They are usually brighter and whiter. Most are nondimmable, so you'll have to live with the brightness.
Do not use one for the gen light. In this position, the resistance will be incorrect and it may cause charging issues. YMMV
DUTCH MAX HEADWORK is offline
post #3 of 29 (permalink) Old Mar 26th, 20, 4:20 PM
Re: 194 led lamps
I installed a multi (4-6 sides) 194 LED in the light in the cap on my pick up. That dang thing is SO BRIGHT its real hard to look at the light,, Very Bright and VERY White. I also have an LED in my 70 Wgn. dome light its OK, Nothing special. I have low power LEDs in the corner marker lamps in my 70 Wgn.
I do know....... TWO styles of 194-LED, The " 4 or 6 SIDED ones are SUPER BRIGHT, the NON multi sided ones are OK.
Robinls5 is offline
post #4 of 29 (permalink) Old Mar 26th, 20, 10:35 PM
leo
Re: 194 led lamps
If you want to have brighter dash and marker lights and don't want led, try Wagner 17177 bulbs!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #5 of 29 (permalink) Old Mar 27th, 20, 6:18 AM
I might have to try those Wagner lights. I tried the LED bulbs and it kept blowing the fuse. I restored my whole dash and replaced with brand new bulbs and it looks pretty good and clear.
ID:	620706   Click image for larger version
hessz24 is offline
post #6 of 29 (permalink) Old Mar 27th, 20, 6:47 AM Thread Starter
Todd
Re: 194 led lamps
Nice, I will try the wagner 17177 bulbs. led is not that great too cool of a light, not good on the eyes
paul bell likes this.
post #7 of 29 (permalink) Old Mar 27th, 20, 9:46 AM
blm
Re: 194 led lamps
In my 69 I changed all my dash bulbs and my aftermarket (water temp & oil pressure gauges) to led bulbs. Also did courtesy, console and dome lights. Got them from Superbrightleds.com. They are available in cool, natural, warm, green and red. I chose the warm as it is the most similar to the tone of the incadescent bulbs. Not as harsh as cool or natural.
I had tried a couple different incadescent bulbs in the gauges and was not happy with the results. The dash lights were always dim and hard to see. I am very happy with the led bulbs. Was afraid they were going to be too bright but definately dont think so.
Cant say I noticed a big difference with brightness in the dome and console bulbs but they stay very cool when illuminated. I had actually burned my fingers before when trying to remove the incadescent dome light bulb. So the led bulbs wont melt the plastic lens.The courtesy bulbs are much brighter.
I did leave the turn signal indicator bulbs in the dash regular incadescent bulbs as the led bulbs require a different flasher.
Somewhere I posted pics of my dash lights with the leds. Have pics comparing one courtesy light with an led and other with an incadescent. Same with the oil and water gauges. If i can find those i will link them.
rjt427 likes this.
blm is online now
post #8 of 29 (permalink) Old Mar 27th, 20, 9:50 AM
Re: 194 led lamps
I assume these are filament bulbs and ARE dimmable? I would like a brighter dash but need to be able adjust it.
LeoP likes this.
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is offline
post #9 of 29 (permalink) Old Mar 27th, 20, 10:23 AM
Re: 194 led lamps
That's good info. The original 194 lamp is 3.78 watts, the 17177 is 5 watts, Of course, it's dimmable.
LeoP likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #10 of 29 (permalink) Old Mar 27th, 20, 10:33 AM
blm
Re: 194 led lamps
Here is a link that compares incadescent bulbs to led bulbs.
https://www.chevelles.com/forums/27-...d-project.html
And this thread has a pic of the instrument bulbs done in leds. Mine are not able to be dimmed. But that is not a factor for me. I was willing to sacrafice the ability to dim for bulbs that actually illuminated the instruments.
https://www.chevelles.com/forums/27-...ckets-led.html
blm is online now
post #11 of 29 (permalink) Old Mar 27th, 20, 11:07 AM
David Estes
Re: 194 led lamps
I understand the LED's not dimmable due to their low amp draw. Anyone ever tried adding a resistor to the circuit to see if that would make them dimmable?
Have you ever stopped to think and forgot to start again??
suprdave1 is offline
post #12 of 29 (permalink) Old Mar 27th, 20, 11:54 AM
blm
Re: 194 led lamps
Dont think they can be dimmed by a resistor. They can however by adding a pulse width modulator. Not sure there is a way to add one of those in an older wiring design.
blm is online now
post #13 of 29 (permalink) Old Mar 27th, 20, 7:19 PM
Deon
Re: 194 led lamps
LED are great if you know what you are wanting.
LED color temp is available from about 2200k to 12000k. 2200k is amber color, 2700k is normal incandescent, 3000k is a little whiter, 3500k is white. 4000k starts to introduce blue. 5000k is probably brightest light output or lumens per watt. Anything higher than 6500k moves towards indigo / purple and reduces lumen output.
LED are dimmable if driver supports dimming. Incandescent diming is what is called sunset dimming. Moves to more yellow or orange color temp. Standard led diming does not do this it is just lowers lumen output in same color temp range.
I just installed LEDs in my dash nice White color and I can see at night. I put a LED chip over the Arctic Air panel. I purchased 3000k to match incandescent and now will need to change to whiter light to match new dash lighting. The LED I purchased dim just fine.
I also have LED in dome and courtesy lights and cabin is nice bright at night when doors are open.
72 Chevelle, 454, TH400, 3:73's
72SS454Chevelle is offline
post #14 of 29 (permalink) Old Mar 27th, 20, 7:32 PM
Re: 194 led lamps
May I ask, which LED bulbs did you buy? You just put them in and they dim with the factory dimmer rheostat in the headlight switch?
How may I help you?
1999 Trans Am-500hp
post #15 of 29 (permalink) Old Mar 27th, 20, 7:33 PM
blm
Re: 194 led lamps
Deon, which brand and part number led bulbs did you install?
I did a fair amount of research on led's and as far as I was able to determine without a PWM dimming is not possible.
Also could you please explain what an LED chip is and what an Artic Air Panel is?
blm is online now
