Oil pressure - Chevelle Tech
 39Likes
post #1 of 73 (permalink) Old Feb 15th, 20, 7:31 AM Thread Starter
Todd
Oil pressure
What is a sufficient oil pressure for a 454? I purchased a chevelle 3 years ago with a 1986 454, not a lot of miles on engine under 10,000. the engine runs great. I was running 10/40 oil but the pressure was about 10psi at hot idle and would not go past 40 psi giving it throttle. So I decided to put 20/50 in the engine that brought it to 15psi and a little over 40psi. I was thinking removing the oil pan and replacing oil pump with a mellon high volume pump, but will a make matters worse? Any skilled thoughts would help.
tday815518 is offline
post #2 of 73 (permalink) Old Feb 15th, 20, 7:38 AM
Re: Oil pressure
I'd say minimum 10psi at idle, and something like 40 at 2k.
Peewee0413 is offline
post #3 of 73 (permalink) Old Feb 15th, 20, 9:18 AM
Re: Oil pressure
My stock 307 has 40 psi at idle. Goes up to 50 psi around 2 grand. 10-15 psi seems to low too me. I am no expert (esp about big blocks) but I did stay at a Holiday Inn last night.
1775SS likes this.
"Life is tough, but it's tougher if you're stupid."
1968 300 is offline
post #4 of 73 (permalink) Old Feb 15th, 20, 9:32 AM
Re: Oil pressure
I always thought 20 for a minimum, and 10 lbs per 1000 rpm..........
66 Malibu
busterwivell is offline
post #5 of 73 (permalink) Old Feb 15th, 20, 10:02 AM
Re: Oil pressure
I thought the manual stated 10 at idle. 20 at idle what I usually see.
post #6 of 73 (permalink) Old Feb 15th, 20, 10:04 AM
Keith
Re: Oil pressure
there is a few variables to consider like bearing clearances and such.
Saltherring and thebeast like this.
Maryland Chevelle Club #682
keithb is offline
post #7 of 73 (permalink) Old Feb 15th, 20, 10:05 AM
Pressures seem fine to me.
JWagner likes this.
yanniziomas is offline
post #8 of 73 (permalink) Old Feb 15th, 20, 2:28 PM
Mr Bill
Re: Oil pressure
Todd,
It should be fine. One thing you might want to do is verify the gauge is correct by plumbing in a mechanical gauge temporarily as a check. I would personally put the 10W40 back in. As long as it stays where it is and does not start going lower I wouldn't worry about it much. That year engine probably never had much more than 40 lbs hot even when brand new.
JWagner, 71350SS, fr8dog and 4 others like this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #9 of 73 (permalink) Old Feb 15th, 20, 4:27 PM Thread Starter
Todd
Re: Oil pressure
I have tried 2 different oil gauges they read the same. I will put the 10/40 back in and if the gauges reads less than 10psi what should I do, replace oil pump with a high volume oil pump?
post #10 of 73 (permalink) Old Feb 15th, 20, 4:45 PM
Keith
Re: Oil pressure
do you hear any odd noises? if not find something else to worry about. there is a reason why car makers used indicator lights in most cars and cars with gauges they had vague markings.
JJ'65 likes this.
keithb is offline
post #11 of 73 (permalink) Old Feb 15th, 20, 4:47 PM
Ole
Re: Oil pressure
You could change out the oil pump spring for one that will give you higher pressure.
Saltherring is offline
post #12 of 73 (permalink) Old Feb 15th, 20, 5:18 PM
Re: Oil pressure
My 454 runs about 10psi at idle & about 40-50 when I get on it. Been running fantastic for years.
If you lend someone $20, and never see that person again, it was probably worth it.
Molly's 70 is offline
post #13 of 73 (permalink) Old Feb 15th, 20, 5:31 PM Thread Starter
Todd
Re: Oil pressure
Changing the spring sounds like a good idea. I will be replacing the rear main seal, so I will have to remove oil pump. Which spring should I use?
post #14 of 73 (permalink) Old Feb 15th, 20, 6:08 PM
Randy
Re: Oil pressure
I installed the purple 52psi springs in my 461, plenty of pressure at idle and high rpm. Chevron Delo 15W-40 oil.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #15 of 73 (permalink) Old Feb 15th, 20, 6:27 PM
Gary
Re: Oil pressure
Changing the spring has no bearing on idle oil pressure unless it's broken or collapsed and the valve is open which isn't the case here since you have 40 psi. A stiffer spring will raise the high engine speed pressure. Right now it opens at 40 psi. That said 10 psi is right on the ragged edge. I would try another gauge like suggested. If that's good you need one of 2 things. Less clearance or more pump capacity. Or thicker oil. 3 things I guess.
gnicholson is offline
