66 Chevelle frame interchangeability? - Chevelle Tech
 5Likes
post #1 of 27 (permalink) Old Jan 27th, 20, 3:03 PM Thread Starter
I need to know if any other a body frames would fit the 66 chevelle with little or no fabrications needed. I got told I could use a 74 Buick frame by a friend has accordingly “has Made the swap before, with just a little lengthening of the frame. I also am considering making a nascar type tube chassis.
S10chevelle is offline
post #2 of 27 (permalink) Old Jan 27th, 20, 4:13 PM
Keith
Re: 66 Chevelle frame interchangeability?
64-67 Chevy Olds and Buick is a direct swap. I have found more of them in junk yards then I did of a 74 Buick.
Maryland Chevelle Club #682
keithb is offline
post #3 of 27 (permalink) Old Jan 27th, 20, 6:44 PM
Is your car lacking a frame or have a damaged frame?
dell72 is offline
post #4 of 27 (permalink) Old Jan 27th, 20, 7:29 PM
& Administrator
https://chevellestuff.net/qd/frames.htm
Mike is offline
post #5 of 27 (permalink) Old Jan 27th, 20, 7:39 PM Thread Starter
it’s a car I’m planing on purchasing, from what I can tell the car is either missing a frame completely or it is highly damaged
post #6 of 27 (permalink) Old Jan 27th, 20, 11:27 PM
I doubt the 74 frame will work, the 66 frame rails are narrower.
David Bates and LeoP like this.
oldcutlass is offline
post #7 of 27 (permalink) Old Jan 27th, 20, 11:45 PM
David
Wow - that's quite the opposite ends of the scale for solving your problem!
This would be a MUCH easier route for you.
FYI - You should at least put your city and state in your signature. This will make it easier for someone to offer you big things like frames if we know how far away you are.
Kirk's67SS likes this.
66 Malibu......back to life with a 427 BB & 4 speed
RAIDER SS is offline
post #8 of 27 (permalink) Old Jan 28th, 20, 6:41 AM
Post up some pictures so we can see what you are working with. It sounds like you are going to be upside down on this thing before you even get it in the driveway.
67
70 (SOLD)
Alwhite00 is offline
post #9 of 27 (permalink) Old Jan 28th, 20, 8:37 AM Thread Starter
I don’t have the car yet, it’s halfway across Indiana and I plan to check the car out in more detail when I get a break from school. I’m just trying to figure out the information before I get the car because even if I don’t buy this one, I do plan to buy and restore a 66 chevelle
RAIDER SS likes this.
post #10 of 27 (permalink) Old Jan 28th, 20, 11:53 AM
I've always said its cheaper to buy than build and have unfortunately proven myself right numerous times. (I'm a slow learner)
My advice would be to save your money until you can buy at least a decent driver.
1965stlhrsrdr likes this.
67
70 (SOLD)
post #11 of 27 (permalink) Old Jan 29th, 20, 1:13 AM
64-67 chevelle 2 or 4 dr will work - 67 has diff rear spring pockets
Cutlass skylark and gto are about 4 in longer in the rear and at least cutlass has diff front frame horns
1966chevelleaholic is offline
post #12 of 27 (permalink) Old Jan 29th, 20, 1:44 AM
Are you sure? I believe all the A body frames are interchangeable for 64-67 including the flat top wagons. Agree on the 67 lower spring pockets for the rear ends, but if the op uses his original rear it does not matter.
post #13 of 27 (permalink) Old Jan 29th, 20, 1:57 AM
Actually, the opposite is true, the UPPER pigtail on the rear springs is different (smaller), starting in 1967.
While the lower mounts (rearend housing) changed, they still use the same size pigtail on the springs... So if you swap rearends, you can use your existing springs. But if you swap frames, you need corresponding (64-66 or 67+) springs that match the frame...
For the OP, ALL '66 Chevelle frames (except the El Camino and wagon) will swap over directly... Wagons and El Caminos only need the rear portions shortened about 3+ inches, all in the rear-most section in front to the rear bumper brackets ( so all body mounts are in the same location (except the rearmost right behind the rear bumper)...
TC #1366
Sold
Sold
1966_L78 is offline
post #14 of 27 (permalink) Old Jan 29th, 20, 11:03 AM Thread Starter
Would it be possible to shorten the rear off the cutlass , skylark or gto, in case I can't find another Chevelle.
post #15 of 27 (permalink) Old Jan 29th, 20, 11:23 AM
David
So True
I have a '67 12 bolt in my '66 and the lower spring pockets work good with original '66 springs. Also - I read that the spring pocket mounting brackets that are welded on the differential are actually 3/4" higher on a 67 diff. versus the 66 differential. So I went to order '67 rear springs, only to find out the '67 rear springs have pigtail mounts on both ends of the spring versus a '66 which only has a pigtail mount on the lower end. Won't work
What they are saying is that it wont take much work to make the Cutlass, Skylark, or Tempest frames to work - so If that is what you can find locally or not too much effort to get your hands on a good one; Go This Route!
