Speedometer gear - Chevelle Tech
 4Likes
  • 1 Post By modern malibu
  • 1 Post By LeoP
  • 1 Post By stanski
  • 1 Post By kermitsass
post #1 of 11 (permalink) Old Dec 1st, 19, 9:34 PM Thread Starter
Speedometer gear
I swapped out the PG in my '66 ragtop for a Turbo 350. Speedometer is not reading correct now. What gear do I need to use at the trans. to get it corrected? And do I need to change out both gear that cable connects to and the one in trans.?
Thanks for your help
Todd
todd j is offline
post #2 of 11 (permalink) Old Dec 1st, 19, 10:01 PM
Mark
Re: Speedometer gear
You should be able to swap the gears(both) from the powerglide to the TH350. It may not require the drive gear(transmission gear) to be swapped, but you need to verify the tooth count and or color on both units to be sure.
LeoP likes this.
modern malibu is offline
post #3 of 11 (permalink) Old Dec 1st, 19, 11:16 PM Thread Starter
I am using the original gear from the PG on the cable and whatever gear came with the trans. Do I need to match the gear on trans to gear on cable or vice versa?
todd j is offline
post #4 of 11 (permalink) Old Dec 1st, 19, 11:41 PM
David
The gear that drives the flexible speedometer cable from the transmission is what you need to change. Remove it from your PG and install it into the turbo 350 in place of whatever gear came with your turbo 350.
66 Malibu......back to life with a 427 BB & 4 speed
RAIDER SS is offline
post #5 of 11 (permalink) Old Dec 1st, 19, 11:53 PM Thread Starter
Will do. Thanks for your help
todd j is offline
post #6 of 11 (permalink) Old Dec 2nd, 19, 12:44 PM Thread Starter
OK so I did a little more research on this issue. I took the tail housing off the PG. It has a 7 tooth gear on shaft and a 20 tooth gear on speedometer "bullet" housing. I didn't use the original set up off PG like I thought. I used the gear set that came on the new turbo 350. I still need to see what that gear set is. The gear on PG shaft is metal and pressed on. Would not be an easy removal. So my question is now can I just change out gear on turbo 350 speedometer housing to XX gear to correct speedometer reading and what tooth gear is needed?
UPDATE: just pulled gear out of "bullet" housing on turbo 350....it has 18 teeth.
Which way do I go now????
Thanks as always for the help.
todd j is offline
post #7 of 11 (permalink) Old Dec 2nd, 19, 11:56 PM
leo
use the 20 gear bullet, should just thread right in!!
David Bates likes this.
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
LeoP is offline
post #8 of 11 (permalink) Old Dec 3rd, 19, 8:48 AM
This ^^^!
USAF Retired (1968-1988)
David Bates is offline
post #9 of 11 (permalink) Old Dec 3rd, 19, 11:22 AM
Stan
I've posted my solution before. I always pursue the easy fix. Grab a handful of the color coded plastic gears. Download a speedometer app on your phone. Drive around and keep changing colors until you get as close as you need to be.
Gunn317 likes this.
stanski is offline
post #10 of 11 (permalink) Old Dec 9th, 19, 1:56 AM
Thor
https://www.chevelles.com/shop/speedo.html
dell72 likes this.
kermitsass is online now
post #11 of 11 (permalink) Old Dec 9th, 19, 2:05 AM
I've used the chart Thor listed on numerous cars. That chart has delivered accurate results confirmed by radar.
dell72 is offline
