Block Plug - What Is It For? - Chevelle Tech
 6Likes
  • 2 Post By Tommy the Cat
  • 1 Post By BillK
  • 1 Post By Rickles
  • 1 Post By Rickles
  • 1 Post By Rickles
post #1 of 15 (permalink) Old Nov 21st, 19, 7:44 PM Thread Starter
ZZ427/480
Wondering what this small plug is for. It's leaking very slightly. I tried tightening it a little, but maybe should go a little more. I assume I'll have to drain the radiator some to remove it if I want to put some pipe sealer on it. Thanks for any help.
Rickles is offline
post #2 of 15 (permalink) Old Nov 21st, 19, 8:03 PM
Bruce
Re: Block Plug - What Is It For?
Originally Posted by Rickles View Post
ZZ427/480
Nize!
Our You Tube Vids:
NickeyChevelle is online now
post #3 of 15 (permalink) Old Nov 21st, 19, 8:17 PM Thread Starter
Thanks, I love it; VERY strong.
Rickles is offline
post #4 of 15 (permalink) Old Nov 21st, 19, 8:46 PM
Looks like an oil gallery plug to me.
70 Camino...Roller
Tommy the Cat is offline
post #5 of 15 (permalink) Old Nov 21st, 19, 9:05 PM
What's leaking from it coolant or motor oil ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #6 of 15 (permalink) Old Nov 21st, 19, 10:40 PM Thread Starter
Coolant. At least it appears to be coming from there.
Rickles is offline
post #7 of 15 (permalink) Old Nov 21st, 19, 10:51 PM
I think it's migrating there. There's not water in that part of the block. I think that plug leads to the gallery above the cam.
71350SS and David Bates like this.
70 Camino...Roller
post #8 of 15 (permalink) Old Nov 22nd, 19, 7:26 AM
Mr Bill
Definitely an oil gallery plug.
LeoP likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #9 of 15 (permalink) Old Nov 22nd, 19, 11:30 AM Thread Starter
Thanks guys, very helpful. I always seem to find good answers here. I looked again this morning and there was a small amount, but not near the plug. I think it's coming from the heater hose above it; the original-style clamps look good, but they don't seem to seal well enough. I've already replaced several because of the same reason, including radiator hoses (which should have been a clue in the first place). I've snugged it up until I replace it. There's a bit of staining where the brass angle fitting screws in, but it's completely dry. I found some wetness under the hose end/clamp when I pressed a paper towel against it; plus the couple droplets on the head.
Name:	Leak 2 B.jpg
LeoP likes this.
Rickles is offline
post #10 of 15 (permalink) Old Nov 22nd, 19, 11:43 AM
The ZZ427 engine is built with the 19170538 block. It's described here:
https://www.chevrolet.com/performanc...n-based-blocks
"Auxiliary oil pressure line added to front of block"
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #11 of 15 (permalink) Old Nov 22nd, 19, 12:23 PM Thread Starter
Thanks, Paul.
Rickles is offline
post #12 of 15 (permalink) Old Nov 22nd, 19, 3:34 PM
Keith
looks like your heater hose is leaking. see if the bottom of the hose is wet
Maryland Chevelle Club #682
keithb is offline
post #13 of 15 (permalink) Old Nov 22nd, 19, 4:57 PM Thread Starter
Thanks, Keith. Yeah, I think it's that clamp. I dabbed a paper towel under it and it was a little wet. I'm going to put a better clamp on it.
LeoP likes this.
Rickles is offline
post #14 of 15 (permalink) Old Nov 23rd, 19, 10:10 AM
Keith
there is nothing wrong with that style of clamp. so don't lose hope
keithb is offline
post #15 of 15 (permalink) Old Nov 23rd, 19, 1:09 PM Thread Starter
I just checked after snugging the clamp up yesterday and it's dry, so maybe the clamp gets a reprieve for now.
CRV CRW likes this.
Rickles is offline
