Vacuum line question - Chevelle Tech
 6Likes
  • 1 Post By JChilders
  • 2 Post By OO52
  • 1 Post By HKalin
  • 2 Post By 72soft-top
post #1 of 8 (permalink) Old Oct 16th, 19, 7:48 AM Thread Starter
Dillon
I replaced my stock intake manifold on 71 Malibu and while doing so I found a vacuum line that connects to the intake and then disappears into passenger side upper fire wall. Do you guys know what it is for? If you follow the line in the picture behind the plug wires you can see where it goes into fire wall. It connects into a dual fitting at the intake, one goes to transmission but not sure on this one. I want to make sure this one is actually connect somewhere so I don’t have a vacuum leak.
D16136 is offline
post #2 of 8 (permalink) Old Oct 16th, 19, 8:17 AM
Jon
Re: Vacuum line question
Is it an AC car? If so it is probably the vacuum line that controls the heat/AC
LeoP likes this.
1972 Chevelle SS 454 "W" code
JChilders is offline
post #3 of 8 (permalink) Old Oct 16th, 19, 10:00 AM Thread Starter
Dillon
It is an ac car, but does not work. I plan to remove the compressor and may purchase all new ac parts in the future. For the time being I may just unhook and plug the port.
D16136 is offline
post #4 of 8 (permalink) Old Oct 16th, 19, 10:24 AM
That line also controls your heater and defroster. The A/C cars use vacuum to switch from A/C to heat to defrost. Heater only cars use cables.
71350SS and LeoP like this.
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #5 of 8 (permalink) Old Oct 16th, 19, 10:30 AM
Hank
The line that goes thru the firewall should only be about the same size as the hose running to the distributor vacuum advance canister. After it goes thru the firewall it should hook up to the heater, A/C vacuum controller.
71350SS likes this.
HKalin is online now
post #6 of 8 (permalink) Old Oct 16th, 19, 1:37 PM Thread Starter
Dillon
Thanks! Guess I will leave it then. Should I be able to see from under dash? My blower does not work. I need to investigate if power issue or bad motor.
D16136 is offline
post #7 of 8 (permalink) Old Oct 16th, 19, 4:22 PM
That vacuum line is needed to switch between heat-defrost- but doesn't affect the blower operation.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #8 of 8 (permalink) Old Oct 16th, 19, 4:57 PM
Here’s some info I found on a previous search
ID:	605632   Click image for larger version
ID:	605634   Click image for larger version
Team Chevelle Member (20 years and counting...
72soft-top is offline
