Frame Boxing for 71 Chevelle - Chevelle Tech
 12Likes
  • 8 Post By lucifershammer
  • 1 Post By yanniziomas
  • 1 Post By DZAUTO
  • 1 Post By Robinls5
  • 1 Post By sselkoe78
post #1 of 13 (permalink) Old Aug 20th, 19, 3:40 AM Thread Starter
Hello Chevelle Fam,
I’m working on a restoration on my 71 Chevelle. I wanted to obtain input or knowledge regarding boxing the original chassis on the A-body Chevelle frames. I’ve purchased full complete protouring suspension with coilovers all around. I was advised to box the frame. My goal is to add an LS3, I’m not trying to drag race, quartered mike or anything just make it a cruiser. Is it really necessary to buy ABC or Hellwing kit to box frame? Any input it’s greatly appreciated. Thanks.
sselkoe78 is offline
post #2 of 13 (permalink) Old Aug 20th, 19, 9:02 AM
Re: Frame Boxing for 71 Chevelle
Look into an el Camino frame. There massive.. They will need cut in the back though..
Your biggest problem is not taking advice from the competition people with there big cams and solid bushings.
I'm in the process now of making a set of stock upper front control arms for my 69 that will give me +5 positive caster. The 73 Chevelle arms look like a winner. The deal is they have rubber bushings that ride smooth. I have SPC arms now with Delrin bushings, they ride rough! My car used to have such a nice ride with the stock suspension..
hydro462 is offline
post #3 of 13 (permalink) Old Aug 20th, 19, 9:13 AM
Lew
Don't box too much leave room to be able to move cross member in and out or if you change transmissions etc. Plus you might want to run something through the frame so leave some access room. Maybe look at a convertible frame to see what they did there.
Lew540 is offline
post #4 of 13 (permalink) Old Aug 20th, 19, 9:49 AM
Mark
You should remove the frame, and there is a lot to do to get it there. Here's what I did to make the cross member adjustable. Look around on the different forums to get an idea on what to do.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #5 of 13 (permalink) Old Aug 20th, 19, 10:12 AM
To answer your question (and others may feel free to disagree with me) - for a daily street cruiser car that you aren't going to race, there is no need to box the frame.
Originally Posted by sselkoe78 View Post
Hello Chevelle Fam,
Clint44, Malibu70, -SS454- and 5 others like this.
lucifershammer is online now
post #6 of 13 (permalink) Old Aug 20th, 19, 11:09 AM
Agree 100%
BTK likes this.
yanniziomas is offline
post #7 of 13 (permalink) Old Aug 20th, 19, 1:54 PM
to answer your question (and others may feel free to disagree with me) - for a daily street cruiser car that you aren't going to race, there is no need to box the frame.
Exactly!!!
But, just for added information, the convertibles and El Caminos were built with boxed frames.
IF, just IF you should come across a junk, donor conv or Elky frame, you could cut off the box channels from the frame rails and weld them onto your frame. Also, conv and Elky tranny cross members are shorter and unique to the conv/Elkys.
LeoP likes this.
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #8 of 13 (permalink) Old Aug 20th, 19, 2:01 PM
I have a 1970 Nomad Sta,=. Wgn. with a 468 and a 700. It has been driven over 39.000 or close to 40.000 highway mile to cruises and shows.
The ride is fantastic and it drives Fantastic. These words are from my wife, She loves to drive the wagon.
Front suspension: Stock uppers & lowers with all moog parts.-- Over the counter GAS shocks.-- 1-1/4" front sway bar-- Jeep steering box.--new STOCK coils.
Rear suspension: Boxed L.C.Arms.--Frame braces--F-41 stock sway bar--All new STOCK rubber bushings--Top left Torque arm has the patch--New style air shocks.
This is what you need for a driver/Cruiser. NOW, If I was the owner of a gas station, I would recommend you should run 110 or 115 octane, @- 8 to 12 dollars a gallon WHY? this would improve the performance of your 307. It would also improve the size of the owners wallet!
The stock O.E.M. parts have worked very well in STREET DRIVEN Cars of all kinds for 50-60-70 years. Unless you are building a " Special Purpose Car " You will get another 50 years of service by using stock O.E.M. parts".
Its your money, Make wise decisions, " Grasshopper ".
72 Greenbrier likes this.
Robinls5 is offline
post #9 of 13 (permalink) Old Aug 20th, 19, 7:21 PM
Bob, I'm glad you mentioned the 307.
MANY, MANY people condemn the 307 as a viable performance engine. And I strongly disagree. The 307 cannot be made into a killer 468, BUUUUUUUUUUUT, dropping in a 350 crank (1/4in stroke) and a .030 bore, you end up with 335 cubic inches---------------that's just 15 inches less than a 350. Then just build it with pistons, cam, heads and other parts just as would be done to build a healthy 350----------------AND YOU KEEP THE ORIGINAL NUMBERS MATCHING ENGINE!!!!
Tom Parsons
TC# 474
#3 FOREVER!!!!!
DZAUTO is offline
post #10 of 13 (permalink) Old Aug 20th, 19, 11:42 PM Thread Starter
Thank you all for the input. It makes it a lot easier to make up my mind. Two other shops just informed me that as long as Im not trying to get 600 hp or more no need to spend money on boxing but can use for suspension or drivetrain. Thank you all once again👍🏽
LeoP likes this.
post #11 of 13 (permalink) Old Aug 21st, 19, 8:50 AM
Originally Posted by DZAUTO View Post
Exactly!!!
I've heard for years how great the convertible frame is, but mine has always felt like a wet noodle. I think it could use a MAJOR amount of stiffening. Also, in my factory assembly manual, I'll swear it lists the SAME part number for the hardtop or the convertible frame on the 72'.
Droptop72 is offline
post #12 of 13 (permalink) Old Aug 28th, 19, 11:35 AM
Just a question for the Rag Top owners. " IF " the chassis & body were not designed to " Twist & Flex ". ( GEE... Its kinda like " Twist & Shout "- The
Isley Bros. ) Why do the rag tops have the brass wedges in the doors?..................... Richard Dawson SAYS-- The answer is ......................................?
Robinls5 is offline
post #13 of 13 (permalink) Old Aug 29th, 19, 2:50 PM
jacking
Endeavor to persevere... Lone Watie -
Proud owner of a bunch of parts that used to be a 70 Malibu convertible
Bcool is offline
