66-67 ride height. Where are you at? - Chevelle Tech
 13Likes
post #1 of 27 (permalink) Old Jul 9th, 19, 5:43 PM Thread Starter
Dennis
I’m just finishing up my 66 project and I like ‘em low. I have dropped spindles and dropped front springs but my lightweight engine still has me sitting higher than I thought I would be.
Rear has 2” lowering springs. Running 18” wheels.
So with all of the various ways we all put are cars together, I’m thinking the common height check would be the front and rear fender lips.
I’ve attached pics of mine. Roughly 25 1/8” kin the front and 24 1/4” in the rear.
What does everyone else have?
ID:	597822   Click image for larger version
67_LS1 is offline
post #2 of 27 (permalink) Old Jul 9th, 19, 10:46 PM
24 1/4” or so front , about 25” rear with 17” wheels/tires.
ID:	597866   Click image for larger version
yanniziomas is offline
post #3 of 27 (permalink) Old Jul 10th, 19, 5:41 AM
Re: 66-67 ride height. Where are you at?
Subscribed
67
70 (SOLD)
Alwhite00 is offline
post #4 of 27 (permalink) Old Jul 10th, 19, 12:23 PM Thread Starter
Dennis
So your lower in the front than mine. But it appears yours might be a wagon or a 4 door so I’m not sure if the rear fender opening shapes differ.
67_LS1 is offline
post #5 of 27 (permalink) Old Jul 10th, 19, 10:12 PM
It is a 4 door, not sure of the differences w/2 doors.
71350SS likes this.
post #6 of 27 (permalink) Old Jul 11th, 19, 12:35 AM
gary
25 1/2 front, 25 rear. Stock older springs.
post #7 of 27 (permalink) Old Jul 11th, 19, 10:46 AM
Greg.
25" Front Wheel/Tire Comb =
............... JEGs Sport Stars#66062 Alum 15”x 7” BS= 4”
............... Cooper Star Fire SF 340 P205/70R/15” = 26.3" Diameter
25.5" Rear Wheel/Tire Combo =
................ JEGs Sport Stars # 555-66086 15" x 10" BS= 5.5"
................ M/T ET Street S/S # 3454 295/55/15" = 27.78" Diameter
Clint44 likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.561
1/8 = 7.411 et / 90.18 mph
1/4 = ??.??? et / ??? mph
Kirk's67SS is offline
post #8 of 27 (permalink) Old Jul 11th, 19, 10:52 AM Thread Starter
Dennis
It appears that my 2” dropped spindles and shorter springs have done zip for lowering.
67_LS1 is offline
post #9 of 27 (permalink) Old Jul 11th, 19, 11:32 AM
What wheels and tires?
All height measurements for comparison should be from center of spindle to a point on the body. That will ignore wheel and tire combinations.
Pioneer4x4 is online now
post #10 of 27 (permalink) Old Jul 11th, 19, 12:20 PM Thread Starter
Dennis
I purposely asked for measurements at the fenders because it ignores the differences in wheel/tire/suspension combinations. Spindle to body would only tell about suspension mods.
I’m only interested in the body height. Which would also tell me about front crossmember ground clearance because they are tied together (unless you used thin body mounts).
67_LS1 is offline
post #11 of 27 (permalink) Old Jul 11th, 19, 1:16 PM
At the fender include wheel and tire, ½ the overall diameter of the tire is spindle to floor. So you have 28" tall tires total, you have 1" lift starting over my 26" tall tires, so with a 2" drop, it would only be 1" lower to the ground.
So, what tires do you have?
bry66 likes this.
post #12 of 27 (permalink) Old Jul 11th, 19, 1:47 PM Thread Starter
Dennis
I get what your saying but your meathod does not take into account weight. Like when you pull an engine and front end goes up, changing spindle to body dimension.
I’m running an aluminum V6 so even with my lowering springs and dropped spindles I’m higher then I would like to be.
Tire diameter is really irrelevant to the fender height because of all the variables, which in my case is weight.
67_LS1 is offline
post #13 of 27 (permalink) Old Jul 11th, 19, 1:50 PM
24" lip to ground. 12.75" lip to center of cap. Tires 195/75r14
Cut Corvette springs.
'66 El Camino, 327, 5 speed, 3.31 posi.
Custom painters don't screw up! They just add more graphics.
Moderator - nevadashooters.com
Tophog is offline
post #14 of 27 (permalink) Old Jul 11th, 19, 3:11 PM Thread Starter
Dennis
Thanks. Is this front or rear andcwhats the other end like?
67_LS1 is offline
post #15 of 27 (permalink) Old Jul 11th, 19, 7:48 PM
Front.
Rear is 22.25" to ground, and about 11" to center of cap. Chevelle rear springs.
Tophog is offline
