Air intake behind the bumper - Chevelle Tech
  • 1 Post By toofastforyou
post #1 of 5 (permalink) Old Jul 2nd, 19, 9:26 PM Thread Starter
Dennis
I currently have my air filter behind the headlights on the drivers side. The filter is currently open to the engine compartment. I知 going to enclose the filter and want to connect it to cooler air from outside the engine compartment.
I知 considering cutting a hole in the inside front fender, the horizontal part forward of the drivers front tire and behind the headlight. This would allow air in from below the car, in front of the front tire but behind the front bumper.
My question is this a high pressure or low pressure area? I could put an elbow below the inside fender to angle the intake forward or sideways or?
Any opinions as to the quality/quantity of air in this area?
67_LS1 is offline
post #2 of 5 (permalink) Old Jul 2nd, 19, 11:16 PM
Jason
I have mine routed like this but on the passenger side. Filter is tucked behind the bumper. (No water driving) It helped for sure. The computer was pulling timing because of the hot engine compartment. On the Controller the IAT went from 170 down to outdoor ambient while running. I looked before doing this about the high/low pressure area could find any solid info.
The cooler air alone is worth it.
Jasons 69 Chevelle is offline
post #3 of 5 (permalink) Old Jul 2nd, 19, 11:32 PM
Claude
Re: Air intake behind the bumper
You'll be getting cooler, more dense air than behind the headlights. I have the exact same setup on my Buick Grand National and the filter is at the end of the ram air tube like you said "forward of the front tire but behind the front bumper". There's no need to put an elbow, just mount the filter vertically and you should be fine. I'm including two pictures of the setup on my GN so you can visualize better what I mean. Hope this helps!
Claude.
Name:	photo copie 7.jpg
ID:	597322   Click image for larger version
Kirk's67SS likes this.
1971 Chevelle SS
toofastforyou is offline
post #4 of 5 (permalink) Old Jul 3rd, 19, 2:39 AM Thread Starter
Dennis
Claude.
My filter will be in a box above the inner fender. Behind the headlights. I知 going to cut a 5 hole in the inner fender to allow air to be drawn up from above hence the mention of an elbow.
Does your filter get wet down there?
67_LS1 is offline
post #5 of 5 (permalink) Old Jul 3rd, 19, 8:13 AM
Claude
Dennis, the reason why my filter isn't in a box is because I go drag racing with my car and the car runs better without a box than when enclosed. These turbo cars need a lot of air and the box doesn't allow enough volume of air to get in fast enough! As for the filter getting wet, I don't think it does but I don't drive that car in the rain.
Claude.
1971 Chevelle SS
