PCV valve - Chevelle Tech
 2Likes
  • 1 Post By oldcutlass
  • 1 Post By novadude
post #1 of 4 (permalink) Old Jul 1st, 19, 2:47 PM Thread Starter
PCV valve
Need a new PCV Valve but see that there are 2 part numbers for a new one. One for a high performance engine and one w/o high performance engine. I would assume that my 350 c.i. with 2 barrel carb and 245 h.p. would not be considered high performance.I wonder what the actual difference is between the two and if it really matters?
old green is offline
post #2 of 4 (permalink) Old Jul 1st, 19, 5:15 PM
Bruce
Re: PCV valve
Diameter of the valve.
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 4 (permalink) Old Jul 1st, 19, 5:39 PM
Re: PCV valve
The difference is the vacuum required to operate, the high performance models use less vacuum.
novadude likes this.
oldcutlass is offline
post #4 of 4 (permalink) Old Jul 1st, 19, 5:56 PM
Re: PCV valve
What he said. I have found that the AC Delco CV774C works well on stock to mild street engines. It also has a 90 deg elbow which makes hose routing a little cleaner (if originality isn't a high priority). I think this is also the valve GM recommends for the 330hp 350 crate engines.
LeoP likes this.
novadude is online now
