Tip for hogged out screw holes on trim or interior - Chevelle Tech
 9Likes
  • 2 Post By 658Chevy
  • 2 Post By gnicholson
  • 1 Post By boyd66k20
  • 1 Post By HKalin
  • 2 Post By 427L88
  • 1 Post By 12stones
post #1 of 15 (permalink) Old Jun 5th, 19, 6:16 PM Thread Starter
I don't know if this is a common trick or not, but I just stumbled onto it. I was replacing the front wheel well trim on my '69 Malibu and once I got it off I saw a bunch of green rubber material in the screw holes. Turns out it was snips of electrical wire. It soon became clear why: the holes in the fender were either too big from the factory for the stock screws or hogged out over the years. The previous owner had cut 1/2" pieces of electrical wire and stuffed them in there, giving the screw something to bite into and tighten. This had held the wheel well trim for at least 15 years. The principle is sound; I've done similar with toothpicks and wood glue when repairing furniture.
The holes in the fender of my car were too big even for oversize screws to tighten completely, and those screws, even though they'd be kind of out of the way, looked out of place. I tried the electrical wire and it worked great. For the holes facing down, I cut the snips to be about 1" long and bent the tip down like a hockey stick and stuck the long end in there to keep it from falling out. Some of the screws bit mostly into the rubber and tightened down just enough, but some apparently bit into the wire and tightened down as tight they would have into metal holes.
I wouldn't use this trick for anything structural or under stress, but it's great for trim or interior pieces where oversize or non-factory screws would look garish.
By the way, I wound't be upset if someone "hijacked" this thread with unrelated but equally helpful tips or tricks.
Kirk's67SS and David Bates like this.
658Chevy is offline
post #2 of 15 (permalink) Old Jun 5th, 19, 6:35 PM
Gary
Re: Tip for hogged out screw holes on trim or interior
May I introduce you to aircraft 10 32 aircraft clip nuts. these things are invaluablehttps://m.aircraftspruce.com/catalog/hapages/04-00153.php?recfer=26754
427L88 and DJsSS like this.
gnicholson is offline
post #3 of 15 (permalink) Old Jun 5th, 19, 7:09 PM Thread Starter
I'll keep those in mind for future issues, but I don't think they would've helped with the trim as the lip on the fender isn't wide enough for the one style and the other style might catch on the top of the tire during a turn.
I do appreciate the tip. That's the kind of stuff I'm hoping people will post.
658Chevy is offline
post #4 of 15 (permalink) Old Jun 5th, 19, 7:50 PM
Gary
they work great on fender lips thats why i posted them. way better than stock sheet metal screws. i drill the hole with a #10 bit, deburr and just slide the clip nut in place. use 3/4 10 32 screws. i have them on all 4 fender lip moldings on my 70. you could also use 8 32 s.another aircraft product to keep in mind are nut plates. rivnuts or speed nuts which are basically clip nuts for sheet metal screws
post #5 of 15 (permalink) Old Jun 5th, 19, 7:51 PM
Greg
Using .030 welding wire in the door holes where the arm rest base screws go was a common fix in the 80's when
these cars were well worn.
71 Malibu
Asst Novas
TechNova is offline
post #6 of 15 (permalink) Old Jun 5th, 19, 7:56 PM Thread Starter
I stand corrected. I'll try those for the next time I need to attach moldings.
658Chevy is offline
post #7 of 15 (permalink) Old Jun 5th, 19, 8:00 PM
wrapping a bread loaf wire tie with the paper on it, around a sheet metal screw, for a too big a hole also works. From Al the machinist. Have to give credit where credit is due.
427L88 likes this.
USN-SSBN 645-G
boyd66k20 is online now
post #8 of 15 (permalink) Old Jun 5th, 19, 8:26 PM
Gary
as easy as they are to get to in this case you could just use a bit behind the lip
post #9 of 15 (permalink) Old Jun 5th, 19, 8:59 PM
Hank
Paper clips. One place they work really good is on the holes that the screws go in that hold the front armrests on. You cut it long enough that when you bend it together you have 2 legs about 1/8" long. You may need 2 if the hole is too big. Insert it in the hole and push the legs over the edge of the hole. Works like a charm and you can pull the door closed without worrying the armrest will come off in your hand.
12stones likes this.
HKalin is offline
post #10 of 15 (permalink) Old Jun 6th, 19, 12:46 PM
Well, I'll have to use that trick Hank, as I do have a "wobbly" arm rest. THNX!
12stones and HKalin like this.
post #11 of 15 (permalink) Old Jun 6th, 19, 1:18 PM
Banned
Cory
dream66 is offline
post #12 of 15 (permalink) Old Jun 6th, 19, 1:39 PM Thread Starter
So, are the kinds of clips you and Gary recommended the correct way to attach the molding piece and the electrical wire is just a shade tree jimmy-rig?
658Chevy is offline
post #13 of 15 (permalink) Old Jun 6th, 19, 1:52 PM
Ditto!
HKalin likes this.
70 LS5 convertible
12stones is online now
post #14 of 15 (permalink) Old Jun 6th, 19, 1:58 PM
Lang
You can also use a small piece of metal (cut up soda can works) if you can get to the back side. My 15 Silverado has several screws holding the bed liner in place. Right after I go it, I saw one laying in the bed. I screwed it back in and called it good. Turns out that it left the Factory with to big a hole.....so I cut a strip about 1/2" wide and 1" long, bent it in half,and half again, took a Awl and punched a hole in the middle....done.
langss is offline
post #15 of 15 (permalink) Old Jun 6th, 19, 9:09 PM
Greg
Same as the welding wire I mentioned, bend it in the shape of a fence staple. G bodies were really bad with the pull straps on doors.
71 Malibu
Asst Novas
TechNova is offline
This Thread is more than 430 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
