Is This a Door Latch Problem? - Chevelle Tech
post #1 of 19 (permalink) Old Apr 22nd, 19, 2:54 PM Thread Starter
On my '67 driver's door, the inside handle must be raised nearly to the top of its travel before the latch will "pop open". The outside button works just fine and the lock, key and button, also works perfectly. Is this a worn latch problem or could the previous owner have used a rod that's a little too long when he built the car? He did a frame-off on the car, so I don't think it's a dirt and old grease thing. I'm wondering if the part of the latch activated by the inside handle could be worn while the rest is OK. It works well except that the handle has to be lifted so high. Any thoughts? Thank you.
Rickles is offline
post #2 of 19 (permalink) Old Apr 22nd, 19, 3:03 PM
Re: Is This a Door Latch Problem?
I had the same problem on my 70. I took the door panel off and lubed the mechanism and it opens easy now without having to lift the handle to the end of it's travel.
70 LS5 convertible
12stones is online now
post #3 of 19 (permalink) Old Apr 22nd, 19, 3:15 PM Thread Starter
Thanks, Mike. I never would have thought a little lubrication would do it. I'll try that. What's good to use: WD-40, White Lithium spray grease, dry lock spray,...?
Rickles is offline
post #4 of 19 (permalink) Old Apr 22nd, 19, 3:34 PM
I just used WD40. I was surprised it worked to.
70 LS5 convertible
post #5 of 19 (permalink) Old Apr 22nd, 19, 3:43 PM Thread Starter
Thanks, I'll try that tomorrow.
Rickles is offline
post #6 of 19 (permalink) Old Apr 22nd, 19, 3:53 PM
A good lubricant is Tri Flow. It has PTFE in it, so it will lubricate better. It is also what a local locksmith recommends for lubricating locks.
https://www.walmart.com/ip/Tri-Flow-...icant/19868616
Hopefully it will help your issue. My '71 does the same thing - even after installing a different latch assembly. I suspect it has something to do with the rods and their attachment points after 48 years.
My Chevelle w/ open headers: http://www.youtube.com/watch?v=Q61TTYXmIsc
http://www.youtube.com/watch?v=YFm_ISn_UDA
WakkoWarner is offline
post #7 of 19 (permalink) Old Apr 22nd, 19, 4:25 PM Thread Starter
Thanks, Brian. I'll look for that, too.
Rickles is offline
post #8 of 19 (permalink) Old Apr 22nd, 19, 5:58 PM
Also check to be sure the door alignment is proper. If it is sagging/dragging on the door jamb pin it will be difficult to open from inside yet easy from the outside. All about leverage.
Blue 69 is offline
post #9 of 19 (permalink) Old Apr 22nd, 19, 8:15 PM Thread Starter
Thanks, Blue, I'll check that, too.
Rickles is offline
post #10 of 19 (permalink) Old Apr 22nd, 19, 9:11 PM
Roy
I've repaired and restored the latch assemblies for my '64. I enjoy diagnostics. Your assembly is OK. I lean toward a bent rod. However, there is a chance the part that the handle operates is 'not quite right'. Wrong part? Offset mounting? Crud that affects travel? Last resort - reset the handle a little lower. :-)
~ Roy in Valley Village, CA
'64 4dr Wagon w/Factory A/C
283 TURBO-FIRE 220HP
rwrising is offline
post #11 of 19 (permalink) Old Apr 22nd, 19, 9:31 PM Thread Starter
Thanks, Roy. I should have some time tomorrow to pull the door panel and have a look. When you say "reset the handle a little lower", I assume you mean reset it on the shaft to, say, point to 4:00 or 5:00 instead of 3:00?
Rickles is offline
post #12 of 19 (permalink) Old Apr 23rd, 19, 5:20 AM
Geoff
Assuming original parts, this sounds like 'lost motion' due to worn parts. A bent connecting rod would open sooner in the handle's travel, not later; it acts like a shorter rod.
You probably have wear in a few places & that cumulatively is resulting in a lot of travel at the 'end of the road', which is the door handle.
Shortening the rod or bending it is probably the easiest fix.
Gtogeoff is offline
post #13 of 19 (permalink) Old Apr 23rd, 19, 8:30 AM Thread Starter
Thanks, Geoff, makes sense.
Rickles is offline
post #14 of 19 (permalink) Old Apr 24th, 19, 9:37 AM
Rick, I'm curious to hear what you found.
70 LS5 convertible
post #15 of 19 (permalink) Old Apr 24th, 19, 10:49 AM Thread Starter
Didn't get to it yet. I'm hoping today with a little luck.
Rickles is offline
Battery drain problem Dcairns560 Troubleshooting 23 Dec 13th, 18 12:38 AM
Low Speed Stalling Problem Dan Orgill Engine 35 Jul 22nd, 16 6:46 AM
HELP!!!1972 chevelle a/c- heater control problem berneemc Electrical & Wiring 14 Jun 2nd, 15 9:22 AM
Crossmember bolt in not straight across...a problem? Gossamer454 Transmission & Driveline 4 Apr 4th, 15 4:01 AM
Help with starting problem Aus SS396 Electrical & Wiring 7 Jan 8th, 13 5:56 AM
