Cowl induction air door (continue) - Chevelle Tech
 2Likes
  • 1 Post By 72soft-top
  • 1 Post By NickeyChevelle
post #1 of 15 (permalink) Old Apr 15th, 19, 5:04 PM Thread Starter
Todd
From what I gather the cowl door is connected to the intake manifold direct vacuum, is that right? along with the check valve.
I tried to bend door a little to get bow, curve in air door, broke a few ribs but I thought that would be the simple part fixing door. I got it to line up satisfactory, flush, it was all good until a fired up the engine, now it sucks it down in the center and when I give it gas lightly the door moves a little I can see it. trying to figure out what to do
tday815518 is offline
post #2 of 15 (permalink) Old Apr 15th, 19, 6:45 PM
That door takes a lot of stress during the opening and closing functions. With some broken areas it becomes weaker. You can slow it down closing with a different vacuum pod, but that may take some trial and error. If the curve of the original is that important for you, I would start looking for an original door.
Team Chevelle Member (20 years and counting...
72soft-top is online now
post #3 of 15 (permalink) Old Apr 15th, 19, 8:30 PM
Bruce
Re: Cowl induction air door (continue)
I just saw an NOS flapper door on eBay go for a buck and a half ($150.00). I was thinking about pulling the trigger and someone else beat me to it... You snooze, you loose.
Our You Tube Vids:
NickeyChevelle is offline
post #4 of 15 (permalink) Old Apr 17th, 19, 7:00 AM Thread Starter
Todd
I ordered one from jegs, I will see how this works out🤞
post #5 of 15 (permalink) Old Apr 18th, 19, 10:01 AM
Stan
Just remember the door will always get pulled down past flush in the centre when the engine is started. Thats the way they all operate. It will only start to open under moderate to hard acceleration. If you want the door to be more active under normal cruising you can put a restrictor in the vacuum line, it does help a bit. If you have engine mods that reduce vacuum from 12 to 8 or less, the door will be much more active at all rpms.
stanski is offline
post #6 of 15 (permalink) Old Apr 18th, 19, 2:29 PM Thread Starter
Todd
Cool , good idea
post #7 of 15 (permalink) Old Apr 18th, 19, 2:33 PM Thread Starter
Todd
Where do I get a vacuum line restrictor?
post #8 of 15 (permalink) Old Apr 18th, 19, 5:34 PM
Well. The Vacuum Delay Valve used on the CI system is probably a little on the large size. I replaced mine but have yet to test it. This may give you a little background if you want to “experiment “?
https://en.m.wikipedia.org/wiki/Vacuum_delay_valve
post #9 of 15 (permalink) Old Apr 18th, 19, 6:54 PM
This is my goal for CI door operation. It’s from DZAUTO. Notice how smooth it opens/closes. He’s using an obsolete valve GM Part 8997937
https://www.youtube.com/watch?v=Xra1mG1yE8Y
post #10 of 15 (permalink) Old Apr 19th, 19, 4:51 AM Thread Starter
Todd
amazing!!!
post #11 of 15 (permalink) Old Apr 19th, 19, 10:05 AM
Stan
I just use a plastic vacuum line connector, fill it with JB Weld then drill a much smaller hole.
stanski is offline
post #12 of 15 (permalink) Old Apr 19th, 19, 10:45 AM
Anyone know what size orifice is needed?
post #13 of 15 (permalink) Old Apr 20th, 19, 11:38 AM Thread Starter
Todd
Does anyone where I can get the vacuum actuator bolt that connects actuator to air door ? 3922128
post #14 of 15 (permalink) Old Apr 22nd, 19, 10:01 AM
Stan
Start with the smallest drill bit you can get and work your way up until the door closes on start up, then increase the hole progressively until you get the amount of action on the door you prefer.
stanski is offline
post #15 of 15 (permalink) Old Apr 23rd, 19, 9:38 AM Thread Starter
Todd
Still working on it. I will post pics and what I did
This Thread is more than 448 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Correct non cowl induction air cleaner spaceace77084 Chevelle Tech 9 Feb 19th, 19 6:43 PM
ULtra Rare 427 NOS Cowl Induction air cleaner 29ster What's it worth? 9 Jan 5th, 18 12:57 PM
1972 Chevelle Cowl Induction Air Cleaner Bandit1978 Restoration Corner 5 Aug 8th, 15 7:59 AM
Will HEI fit under cowl induction air cleaner? geewez Engine 3 May 30th, 15 1:48 AM
TBI system and use of stock cowl induction air cleaner assembly barnett90 EFI 2 Jan 9th, 15 9:17 AM
