Radiator Core Support - Chevelle Tech
 2Likes
  • 1 Post By Dean
  • 1 Post By Dean
post #1 of 14 (permalink) Old Apr 8th, 19, 2:05 PM Thread Starter
Just when I think things are wrapping up, another hole starts leaking water through the dam. I'm in need of a 1970 Chevelle big block radiator core support? Just found out I have an after market one installed and I'm trying to keep this car as original as possible.
brycez is offline
post #2 of 14 (permalink) Old Apr 8th, 19, 3:20 PM Thread Starter
Re: Radiator Core Support
What is the difference between a small block and big block core radiator support? I see several small block for sale, however, don't know the difference.
brycez is offline
post #3 of 14 (permalink) Old Apr 8th, 19, 4:07 PM
The "small block" core support only has three bolts that hold the top plate on rather than four and a smaller cut out for air flow into the radiator but it's fairly easy to change both of the above to use it on a big block.
BTW, the reason for the quotation marks is not all small blocks had the so called "small block" core support.
fishhead likes this.
post #4 of 14 (permalink) Old Apr 9th, 19, 11:04 AM Thread Starter
Thank you for the information!
brycez is offline
post #5 of 14 (permalink) Old Apr 17th, 19, 12:05 AM Thread Starter
I know the difference for the radiator top plate, however, what is the difference in the core support that surrounds the radiator for a big block and small block?
brycez is offline
post #6 of 14 (permalink) Old Apr 17th, 19, 4:59 PM
Terry
The difference is the size of the center opening, where the rad mounts. Terry
68-13427 is offline
post #7 of 14 (permalink) Old Apr 17th, 19, 6:11 PM
Like was said, the air intake opening can be cut out.
Also a couple of differences, one is the number of headlights and another is an extension is added on the bottom for 4 row radiators.
68-13427 likes this.
post #8 of 14 (permalink) Old Apr 18th, 19, 12:52 AM
Dean - do you have a picture of the extension added for 4-row radiators? One of your pictures is not displaying for me.
novadude is online now
post #9 of 14 (permalink) Old Apr 18th, 19, 6:30 AM
If you are going after function, not total originality, as stated it is easy to modify the opening and relocate the top holes. You just need the longer top support plate that attaches with the 4x screws. It will be undetectable and appear for anyone looking under the hood. The lower support also has a position to mover the lower rubber cushion over. Did it back in the late '70s.
zookpr is offline
post #10 of 14 (permalink) Old Apr 18th, 19, 12:01 PM
https://www.chevelles.com/forums/att...8&d=1414709426
https://www.chevelles.com/forums/att...3&d=1328367958
post #11 of 14 (permalink) Old Apr 18th, 19, 2:38 PM
Still can't access.
post #12 of 14 (permalink) Old Apr 18th, 19, 3:06 PM
Radiator supports aren't just based on engine size. My 68 L79 with AC (C60) has the larger Radiator support with 4 bolt top plate and with the K02 heavy duty clutch driven fan assembly, I believe all BB and AC cars had heavy duty cooling which used the larger radiator support
Billdini is online now
post #13 of 14 (permalink) Old Apr 18th, 19, 4:13 PM
Can you see them here? (post #11)
https://www.chevelles.com/forums/32-...ifference.html
post #14 of 14 (permalink) Old Apr 18th, 19, 7:33 PM
Yes. Thanks! I tried doing a search but wasn't finding that post.
Radiator Support Removal txflash Chevelle Tech 3 Nov 13th, 18 10:53 AM
Radiator support bushings (Lets get to the bottom of this!) m22chevy Body Shop 3 Feb 13th, 16 9:46 PM
64 core support info....? Antalamo Body Shop 4 Nov 27th, 15 1:57 PM
terrible goodmark core support fit blown496 Body Shop 10 Apr 29th, 14 11:20 AM
