Where to buy 12 bolt? - Page 2 - Chevelle Tech
 18Likes
post #16 of 22 (permalink) Old Mar 31st, 19, 9:33 AM
Re: Where to buy 12 bolt?
Originally Posted by Kirk's67SS View Post
I got sick and tired of Rebuilding the 12 Bolt in my 67
as every year it was rebuilt it would stop working or break something the next year
Bought a S60 from Strange that was a direct bolt-in with Brackets installed plus Ford Ends
now not afraid of the Rearend in the car not working or Breaking at the Track
over 5 years of Street/Hwy Cruzin and Weekends at the Track with no problems
THIS^
Clinton, I don't know your actual power level or how much racing you'll do on sticky tires but out of the three rears (12 bolt, 9 inch and Dana), the 12 bolt is the weakest. Long time racers have a 9 inch or Dana 60, and they'll be built by Strange.
Kirk's67SS likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is online now
post #17 of 22 (permalink) Old Mar 31st, 19, 3:30 PM
Lang
Originally Posted by dell72 View Post
I believe he sold the car and pursued a hobby associated with motorcycles. His videos never fail to impress me. My goal is to make my car launch like that for the shear wow factor alone.
Well .... no matter what, I never failed to be blown away at how not only fast, but just straight as an arrow that car would run......Motorcycles....not interested...way to many "Organ Donors In Training"......
dell72 likes this.
langss is offline
post #18 of 22 (permalink) Old Mar 31st, 19, 9:55 PM Thread Starter
The motor will be over 620hp and I know, Iíll want more eventually. Quick performance pricing does seem noticeably cheaper. Iím Leaning more toward them but Iíll make some phone calls first.
Clinton70 is offline
post #19 of 22 (permalink) Old Mar 31st, 19, 10:04 PM
FWIW, years ago, I wiped the teeth off the pinion gear in my 9 inch. 600hp, 590 lbs tq, numbers at flywheel.
How may I help you?
1999 Trans Am-500hp
post #20 of 22 (permalink) Old Apr 1st, 19, 7:22 AM
My 12 bolt lived just fine at 1000 hp, 800 ft lbs of torque. 1.21 60' times, 33 spline axles and spool.
shovelrick and paul bell like this.
Ray
bracketchev1221 is offline
post #21 of 22 (permalink) Old Apr 1st, 19, 8:05 AM
Lew
I think if you get the right parts from Moser it can take a lot more power than the stock 12 bolt. They have fixed all the areas that are know problems with 12 bolts. Weak house, 33 or 35 spline axles versus the 30 spline, Ford end bearings, Robust posi unit, 1/2 inch studs holding the carrier in, 1350 series U joint. It has 12 bolts on the back cover but I think that is about where it stops on what they left original on the rear. The ring gear still is 8.875 so that could be an issue. Ford 9 inch is a proven piece. Of course the Dana 60 is such a massive unit to begin with you really don't need anything with the S60.
Lew540 is offline
post #22 of 22 (permalink) Old Apr 9th, 19, 6:53 PM Thread Starter
Thank you all for the input. Iíve placed an order with Quick Performance. I got a really good deal on a 3rd member: Nodular Daytona style with spool and set up for 35 spline axles. Iíll post some pics once itís delivered and set up.
Broken Bolt, Long rkd Bench Racing 7 May 27th, 18 10:57 PM
12 bolt cross shaft bolt and posi pre-load springs 1966_L78 Transmission & Driveline 21 Dec 23rd, 17 2:06 AM
Replace head bolt ? il69smbk48 Engine 30 Oct 2nd, 17 11:14 PM
What rear end did I just buy? 10 bolt cover, 12 bolt ring gear 72ragtop Transmission & Driveline 7 Nov 14th, 14 3:31 PM
10 bolt to 12 bolt joes66 Brakes, Suspension & Steering 10 Oct 1st, 14 2:06 PM
