Cowl induction benefits - Page 8 - Chevelle Tech
 93Likes
post #106 of 125 (permalink) Old Jul 9th, 19, 9:31 AM
Re: Cowl induction benefits
I tried what someone else was talking about earlier in this thread regarding "moving" the elec solenoid forward to hold inner door open.
Well the power wire "spade" wont allow the solenoid to be "pushed" far enough forward to hold the inner door open fully.
So,
I simply popped off the "hinges" which allowed me to remove the inner door completely so its wide open all the time now. In order to make it truly outside air only I blocked off the CI air cleaner "snorkel" so it wont ingest any under hood hot air only outside air which is substantially cooler.
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
Strange 12bolt w/4.10
1971ss454Elco is offline
post #107 of 125 (permalink) Old Jul 10th, 19, 7:50 AM
Good idea i would say the engine is pretty much just drinking outside are.And when your moving your getting a draft of outside air to the top of that air cleaner
ranvette is offline
post #108 of 125 (permalink) Old Jul 10th, 19, 9:29 AM
Harry
So,
I just bent the spade back 90 degrees and moved it forward and clamped it. I still kept it plugged in. I unplugged it at the gas pedal.
Harry
hjdca is offline
post #109 of 125 (permalink) Old Jul 10th, 19, 10:31 AM
Originally Posted by 71350SS View Post
Here you go Tom, all the way back in the late 50's on the road race Corvette's called the air box cars.I don't know if this is the first but this is pretty early for this kind of option,its a 1957 Corvette.
https://www.hagerty.com/articles-vid...irbox-corvette
The 283 Fuelie engine was rated at one HP per cube but the air box cars were about 300 HP per the article.
Chevy's first time with a factory cold air option for the engine was in 1957 on the air box Corvette's.This was a race only option and required a bunch of racer type options intended mostly for road race style cars not really suited for drag racing or Nascar. Required were Fuel injection 4 speed trans positraction rear and radio and heater delete which made some other things posible.This was so the Corvettes could compete against the Jags and Ferrari's of the day.
That's 1957, so the Chevy engineers knew what to expect from cold air induction on the cowl hoods of the 1970's.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #110 of 125 (permalink) Old Jul 10th, 19, 11:35 AM
hummmm.
Marc S
71 SS 454 ELCO
Edelbrock Proflo4
TKO600
post #111 of 125 (permalink) Old Jul 11th, 19, 9:19 PM
I would buy it would make up to 17 HP more.But depending on temps outside and all that sort of thing.In other words there is a Little power there. But a varying amount.
ranvette is offline
post #112 of 125 (permalink) Old Jul 13th, 19, 9:46 AM
This is interesting to.I think most of us must have felt the flow threw astro ventilation vents over the years when there on.A nice little breeze while the car is moving.That is about the same breeze a cowl induction entrance would have.With the car moving.The source for those vents is in the cowl.
ranvette is offline
post #113 of 125 (permalink) Old Jul 13th, 19, 10:48 AM
What happens to the force of the ‘breeze’ when the flapper on top opens?
The biggest problem facing America today is that lies are so widely accepted as truths.
Alan F is offline
post #114 of 125 (permalink) Old Jul 13th, 19, 12:09 PM
I would say by the way my 3 pieces of ribbon were pulled flat to the screen at full throttle.And this was from 4000 to 5600 rpm.The air is drawn faster than its breeze.(A able to pull by demand type system)Makes sense there is a good amount of air being inhaled by a 396 turning higher rpms.With my K&N filter there is a lot of intake noise as well when that door opens.And the dynomax super turbo mufflers/and headers are just right to still hear plenty of intake noise.A side note the vac door is not as active on my auto as a 4 speed.Unless i force the engine to bog before a down shift.So durring my ribbon test that door was about a 1/4 way open
ranvette is offline
post #115 of 125 (permalink) Old Jul 13th, 19, 12:20 PM
blm
This is comparing apples to oranges. Astro Ventilation works off a ram air principal. Cowl Induction doesnt work off ram air it works off vacuum.
An engine with a big cam is going to produce less vacuum at a certain rpm than a smaller cammed engine. Two different Chevelles traveling at the same speed are going to experience the same pressure at the cowl. Vacuum vs ram effect.
blm is offline
post #116 of 125 (permalink) Old Jul 13th, 19, 3:57 PM
The air supply to the vents in a chevelle(a none ac car) is from the cowl.Not ram air forced into the openings.On left and right side of the cowl.
ranvette is offline
post #117 of 125 (permalink) Old Jul 14th, 19, 10:30 AM
Harry
Two things greatly control the action of the top cowl hood flapper:
The one way check valve hooked up to the vacuum which opens the flapper door and allows it to close slowly. If you get rid of that one way check valve, then, the door opens quickly and closes quickly.
In addition, there is a piece that rests on the vacuum canister that is connected by one screw to the flapper. If you adjust the tension of this one screw and the orientation of the piece on the vacuum can (forward or back), you can adjust the action and opening and closing clearances of the flapper.
Harry
hjdca is offline
post #118 of 125 (permalink) Old Jul 15th, 19, 1:45 AM
The infamous Car and Driver 1964 GTO Road test car that was provided by Pontiac Motor Division also had an opening from the cowl vent through the firewall above the heater box to a sealed air cleaner. The 67 Camaro Z/28 also pulled air from an opening in the firewall that got air from the base of the windshield, this was before the infamous 69 model Cowl Induction hood. The area at the base of the windshield is a source of high pressure, the OEM's knew that, NASCAR knew it also. That being said, I believe my 70 Cowl Induction is more of a gimmick than a real performance enhancer. What I enjoy about them is when people tell me mine works "backwards" because "it's supposed to flip open when you hammer it" I just kinda laugh...
70 El Camino SS 396/TH400
67 Cutlass Supreme convert LS3/4LE85
65 GTO convert Tri Power 4 speed
65 Corvair Corsa Crown Conversion (Mid engine 350)
05 Silverado 2500 Duramax/Allison
06 GTO 6 speed
11 Honda Accord 6 speed coupe
14 Harley Davidson Electra Glide Ultra Limited
19sixty5 is offline
post #119 of 125 (permalink) Old Jul 15th, 19, 8:24 AM
blm
So I guess the air going into the Astro Ventilation is not produced by the effect of the vehicle traveling at a speed and having an opening to collect air from the pressure that the traveling creates ( ram air) I guess it happens by magic.
Same thing as rolling your window down. (Ram air)
blm is offline
post #120 of 125 (permalink) Old Jul 15th, 19, 12:51 PM
Its by the air pressure in the cowl.Down flow into cowl.I guess you consider that ram air.I guess cowl induction would be ram air to.By what ever principle you choose air is forced into those vents
ranvette is offline
Trying to track down additional 1972 SS 454 Real "W" Convertibles skryla Convertibles 728 Feb 21st, 18 2:22 PM
Cowl induction hood versus non cowl induction appearance mersol Body Shop 11 Jan 17th, 17 11:32 PM
New to Forum w/1972 SS 454 4 Speed Vert elliet1964 New Member Introductions 14 Aug 7th, 16 6:00 PM
70 Chevelle Cowl Induction Hood jjr158 Troubleshooting 24 Sep 24th, 15 8:12 PM
issues with cowl induction on 72 Chevelle 69Chevelle396/375 Troubleshooting 3 Sep 2nd, 13 9:00 AM
