Front End Sag on Jackstands? - Page 3 - Chevelle Tech
 29Likes
post #31 of 37 (permalink) Old Feb 15th, 19, 11:13 AM
Re: Front End Sag on Jackstands?
You can add me to the list of chipped paint from opening the door while on a 2 post lift. Solid frame, poly bushings everywhere, even added the "extra" body mount in the middle of the rockers. If you've ever had your car down to a bare frame, you'll know how flimsy these things are.
1969 Beaumont
1977 Bronco
The rest are boring responsible adult vehicles not worth mentioning.
Chris27 is offline
post #32 of 37 (permalink) Old Feb 15th, 19, 11:36 AM
Originally Posted by 72soft-top View Post
For what its worth, ANY jack stand will make a convertible deflect. Just the nature of the beast without the metal roof structure support
Convertible may sag a little more than a hard top but it really doesn't matter, it depends on where the jack stands are placed on either body style.
Placed under the control arms, the weight distribution is no different the car setting on the tires, not being raised up at all.
post #33 of 37 (permalink) Old Feb 15th, 19, 11:42 AM Thread Starter
These responses have really been helpful; gave me many things to look out for. I think I'll be able to avoid any chipped paint. Thanks everyone.
427L88 likes this.
Rickles is offline
post #34 of 37 (permalink) Old Feb 15th, 19, 12:45 PM
Pay attention!
Watch your door gaps closely while starting your lift.
Check door gaps while lifting.
Use your best judgement as to whether your gaps are getting
to tight to proceed with task scheduled...
Especially opening a door if you have to!
Don't forget!
427L88 and DUTCH MAX HEADWORK like this.
LKN BCK is offline
post #35 of 37 (permalink) Old Feb 15th, 19, 1:26 PM
I have to say, it really, really sucked not being aware of this , winging the door open ( working on shifter), and hearing that nasty, nasty sound. I didnt even catch it at first. stepped away to light a smoke ( I was dumb back then) and wondering how bird poop got on the darn front fender. When I examined it, it was the PRIMER! and that nasty nasty noise made sense now. Big chunk of paint came off.
A near flawless paint job to boot!
LISTEN TO DAN!
post #36 of 37 (permalink) Old Feb 16th, 19, 12:48 PM
Richard
Originally Posted by V1rotate View Post
I noticed that that the sag was very pronounced on my 70 while the engine was installed but the front clip was off, once the fenders were installed, it seemed better. Apparently, the fenders add some rigidity to the front structure.
Bingo!
It also flexes when jacking from the front and is the very reason that I will be adding a removable forward support structure to my '68 El Camino when I convert to a 'Glass tilt front.
Have to say I am disappointed that the frame is so flexible but not too surprised since it is really just a simple "Ladder" type.
A properly installed full cage can stiffen the chassis quite a bit but is not common for street cars.
Maybe I will look into what it would take to add some braces from the cab area to the frame for cars with steel fenders.
Always looking for a new product to develop, but I suspect few of us would see this as enough of a problem to buy them.
At these gas prices I want it 100+ octane, leaded, and my windshield washed!
Richard/SIA is offline
post #37 of 37 (permalink) Old Feb 17th, 19, 10:07 PM
I remember the first time I jacked up the front end and placed the jack stands behind the front wheels. After changing the oil I reached in the window to start the car, and it made a hell of a racket. The frame sagged enough that the fan took out the top of my radiator shroud. Broke a big chunk out of it. After that I always kept the jack under pressure if I had to start the car jacked up. I still used the stands, just took some of the weight off them
396/Turbo400/3000rpm stall converter
396/Turbo 400/4:10 Posi/Frame Off Restoration
396/4 spd/3:31 12 bolt posi
Black 1970/LS5 454/4 spd/ 3:31 Posi
tireburner396 is offline
70 new front end kit? High perf - pro tour 70 nialator Brakes, Suspension & Steering 11 Nov 17th, 15 9:16 PM
71 with 69 front end? antoniov1 Chevelle Tech 9 Aug 14th, 15 4:53 PM
NVH in rebuilt front end JPS Brakes, Suspension & Steering 9 Jun 4th, 15 4:32 PM
high pitched sqeak in the front end beavliveson Brakes, Suspension & Steering 18 Sep 8th, 14 7:07 AM
front end height BigTime_ Brakes, Suspension & Steering 2 Dec 18th, 12 11:21 AM
