67 dash removal - Chevelle Tech
post #1 of 8 (permalink) Old Oct 13th, 18, 11:02 PM Thread Starter
67 dash removal
I’ve got it all loose except for cluster wiring. Any advice out there on this?
Chevelle53 is offline
post #2 of 8 (permalink) Old Oct 13th, 18, 11:20 PM
Re: 67 dash removal
Be patient and slowly pull out the blubs....if your referring to this.
Aaron is offline
post #3 of 8 (permalink) Old Oct 13th, 18, 11:41 PM
Re: 67 dash removal
Originally Posted by Chevelle53 View Post
Iíve got it all loose except for cluster wiring. Any advice out there on this?
Did you drop the steering column? Need to unhook the column-to-firewall plate and maybe remove the steering wheel (provides more room to remove the dash). On a '67 with the collapsible column, not sure if you need to unhook the column from the steering box or?
TC #1366
Sold
Sold
1966_L78 is offline
post #4 of 8 (permalink) Old Oct 13th, 18, 11:42 PM Thread Starter
Is there some kind of color code to get the lights back in the right holes?
post #5 of 8 (permalink) Old Oct 13th, 18, 11:43 PM Thread Starter
Yeah I dropped the steering column.
post #6 of 8 (permalink) Old Oct 13th, 18, 11:58 PM
terry
Re: 67 dash removal
The back of the cluster is stamped with for what bulb goes where. The wires are color coded, but you will need an electrical diagram or assembly manual, if you don't mark which one goes where on removal...
mytmouz is offline
post #7 of 8 (permalink) Old Oct 14th, 18, 12:45 AM
Re: 67 dash removal
Mark them with tape telling location where they go back to...
LKN BCK is offline
post #8 of 8 (permalink) Old Oct 14th, 18, 8:20 AM
Re: 67 dash removal
Or take a picture with your phone.
67
70 (SOLD)
Alwhite00 is online now
This Thread is more than 470 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
