Drive shaft - Chevelle Tech
post #1 of 5 (permalink) Old Aug 1st, 18, 12:39 AM Thread Starter
Drive shaft
Hey guys I’m changing from an automatic to a Muncie 4 speed in my 67 Chevelle. Does anyone know if the drive shaft will be the right length? I know I’ll have to change the yoke if it’s not a 27 spline but just thought about the length deal. Thanks in advance
Chevelle53 is offline
post #2 of 5 (permalink) Old Aug 1st, 18, 12:53 AM
which automatic?
yanniziomas is online now
post #3 of 5 (permalink) Old Aug 1st, 18, 12:54 AM
Re: Drive shaft
with my M22 and 12 bolt, my driveshaft was 54.75" if I recall correctly. U joint to U joint.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #4 of 5 (permalink) Old Aug 1st, 18, 12:59 AM
Jon N.
Re: Drive shaft
A glide, a TH350 and a Muncie are all nearly the same length. TH400 is different.
Jon N.
dyno jonn is offline
post #5 of 5 (permalink) Old Aug 1st, 18, 1:31 PM
Re: Drive shaft
Originally Posted by Chevelle53 View Post
Hey guys Iím changing from an automatic to a Muncie 4 speed in my 67 Chevelle. Does anyone know if the drive shaft will be the right length? I know Iíll have to change the yoke if itís not a 27 spline but just thought about the length deal. Thanks in advance
If changing from a Powerglide or TH350 (and the 200-4r), to a 1963-1970 Muncie (except the 1970 M22), the same driveshaft and yoke can be used.
Later M22 (beginning in 1970?) used the larger output which required a larger yoke (TH400 size)... In 1971, the Muncie was slightly longer, but I am not sure if it was long enough to make a difference, or if the yoke will slide in enough to compensate for the extra length... And of course, the TH400 ( and 700-r4) are longer and use the larger yoke...
TC #1366
Sold
Sold
1966_L78 is offline
This Thread is more than 496 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
