roof weatherstrip channel - Chevelle Tech
  • 1 Post By dream66
post #1 of 12 (permalink) Old Apr 5th, 18, 10:17 PM Thread Starter
Does any one know what to use to seal the roof weatherstrip channel
Gold70SS is offline
post #2 of 12 (permalink) Old Apr 5th, 18, 10:27 PM
Re: roof weatherstrip channel
https://www.chevelles.com/forums/12-b...am-sealer.html
Here is a link it was just talked about what different members suggest
69 Chevelle Conv 396
69 Chevelle Hardtop
Nothingbut69 is offline
post #3 of 12 (permalink) Old Apr 6th, 18, 12:32 AM
IMO, seam sealer is too thick and stiff for the weatherstrip channel. The WC on my car had a very thin foam strip that fell apart as I removed it... I would think a thin, easy to squish foam tape of maybe some sort of weatherstrip adheasive...
TC #1366
Sold
Sold
1966_L78 is offline
post #4 of 12 (permalink) Old Apr 6th, 18, 12:37 AM
On the driprail?
69 Chevelle Hardtop
post #5 of 12 (permalink) Old Apr 6th, 18, 12:59 AM
Levon
3m Black weather-strip adhesive. Apply in sections to the rubber then wait for it to get tacky and install. Tape the weather-strip on to apply some pressure. Should be good to go.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #6 of 12 (permalink) Old Apr 6th, 18, 1:33 AM
3M black weather strip adhesive apply sparingly to both surfaces to be joined spread thin with a squared off Popsicle stick allow to get tacky and stick them together they will stay stuck. If your talking about the stainless piece screwed to the drip rail there is something there also but I don''t know what it is, sorry.
mbickle1 is offline
post #7 of 12 (permalink) Old Apr 6th, 18, 8:16 AM
Walt
I've been using McMaster Carr P/N 8694K67 closed cell tape for years on various GM, Ford, and Mopars. Works great does not hold water, applies with it's own sticky back adhesive. 1/8" thk x 3/4" wide
Mcmaster Carr Part Number 8694k67
wahubb is offline
post #8 of 12 (permalink) Old Apr 6th, 18, 8:30 AM
Don
I'm not a big fan of Motor City Musclecar(Inline Tuube) but they do have it listed on Ebay,item #201033833139. It is one of the items I used from them in the past that actually was as described and worked,not vendor bashing just relaying past experience with them.
Not sure what year your car is,but I know that on my "66" the roof rail channel holes are slotted for adjustment in and out.
Don B is offline
post #9 of 12 (permalink) Old Apr 6th, 18, 10:42 AM
Walt
Looks just like what I get from McMaster Carr for 50' @ $8.00
wahubb is offline
post #10 of 12 (permalink) Old Apr 6th, 18, 11:33 AM
Rope calling, available at most hardware stores. Lowes has it for under $5.
Ed C.
70 SS L34 Auto project
57 Belair hardtop project
Always looking
EdCarpenter is offline
post #11 of 12 (permalink) Old Apr 6th, 18, 12:19 PM
Cory
The OP requested a seal material for attaching the weatherstrip channel to the roof rail. The channel (on a 66) is a 13/16" wide stainless steel channel that is installed beneath the roof rail and has a factory installed 3/4" wide adhesive backed foam strip sandwiched between the channel and roof rail. The rubber weatherstrip is insertred into the channel with or without adhesive. I prefer NOT to use adhesive,
When disassembling my 66 chevelle for full restoration there was also a small patch of black caulk (like 3M rope caulk) pressed between the channel and roof rail at the tight corner at the wing vent junction.
wahubb is correct: Mcmaster Carr Part Number 8694k67 for the 3/4 foam tape is the proper seal to use.
If necessary - 3M or equivalent flexible rope caulk is appropriate for filling in tight corners.
sstom66 likes this.
dream66 is offline
post #12 of 12 (permalink) Old Apr 6th, 18, 1:02 PM
We use this on Chevelle Restorations and most Fords,
Works perfectly..
About $6.00
https://www.homedepot.com/p/Frost-Ki...447H/100122697
1953 Chevy Bel Air 4 door.
1968 Chevy C20 CST Longbed.
1967 Malibu 396 Powerglide.
Cal Malibu is offline
This Thread is more than 687 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
