Chevelle Tech - View Single Post - No inner fenders, will that pass tech inspection at the track?
post #3 of (permalink) Old Jul 8th, 13, 6:28 PM Thread Starter
budsthe3
Re: No inner fenders, will that pass tech inspection at the track?
If I did remove the front inner fenders, can I still pass tech inspection with the steel braided heater hoses supported on the small lip from the outer fender under the hood?
Plus the electrical wiring on the driver's side is mounted on the driver's side inner fender, if I wrap that with some protected covering do you guys think the car will still pass?
Or would I have to eliminate the heater hoses, and re-route the wiring on the driver's side?
I just remembered that stuff now.
70 Chevelle SS454
454, 3964291 Heads, Manley Race Flo valves, Crane Valvetrain, 226/236 dur, 534/553 lift
Holley 750, Edelbrock RPM Air Gap, Accel ignition,
TCI TH400 B&M 3000 stall, 3.73 posi, Lakewood traction bars.
budsthe3 is offline
