I'm missing a sill type plate - Chevelle Tech
post #1 of 6 (permalink) Old Jan 21st, 16, 9:06 PM Thread Starter
Kurt
I've tried to find this missing trim piece to no avail. Any help from you 4 door gurus will be extremely appreciated. I don't know if there was one (looks like screw holes) and if so what they are called.
1966, this pic is taken from the back seat looking at the right/passenger side. That black thing is the retractable seat belt I installed - not factory. The left side is missing too. The car was leaking from the cowl due to it being plugged with tree debris and the carpet was ruined. The previous owner (flipper) replaced the carpet you see. I cleaned the cowl. In his defense he did disclose that the car leaked while handing me the keys (at least he was a nice flipper).
Thanks!
Kurt
made2cut is offline
post #2 of 6 (permalink) Old Jan 27th, 16, 4:08 PM Thread Starter
Kurt
Re: I'm missing a sill type plate
Dang, 100+ views and nobody can tell me if there is supposed to be a trim piece here or not?
1966 283 4 door - It's got room for my dog
made2cut is offline
post #3 of 6 (permalink) Old Jan 29th, 16, 9:27 PM
I found that a bit a funny cause now there are over 200 views, I guess not many four door gurus around. After viewing a lot of images on google I found two pics that were relevant but they were not conclusive -as in it was not a close up shot and could not tell what was there. I viewed a pic of my 4 dr wagon and there is nothing in that area. This could be cause its a 64 though. It appears, if it's like that on both sides, that possibly some sort of plastic molding (similar to the headliner perimeter moldings) would go there to hide carpet /area seam. You would have to buy oem used or get creative and Fab a piece to put there, which would be easy. And you would still have to paint the part to match your interior color as needed. Good luck.
68Cpe307 is offline
post #4 of 6 (permalink) Old Jan 31st, 16, 7:02 PM Thread Starter
Kurt
Thanks for the reply Ed. Yeah, I was kind of headed toward fabing a piece from some sheet metal to see how it looked (card board pattern first of course).
made2cut is offline
post #5 of 6 (permalink) Old Feb 3rd, 16, 9:15 PM
Just saw this. I have a 67 Wagon - the original carpet would have gone up the pillar a couple of inches and been attached via 2 screws that install into the holes evident in your image (if 66 and 67s are the same).
The carpet has a vinyl trim strip sewn on the raw edge of the carpet that goes up the pillar, and the vinyl edge extends a bit under the front and rear sill plate. I had Trim Parts custom make the front carpet for my 67 to accommodate this.
I don't seem to have any pictures of it unfortunately.
Mark
Mark
ACES #: 06934
TriState Chevelle Club
67 Malibu Station Wagon
markbcvg is offline
post #6 of 6 (permalink) Old Feb 4th, 16, 8:51 AM Thread Starter
Kurt
Thank you so much Mark for solving the mystery!!!
I knew somebody out there had to have the answer, makes sense too.
Thanks again!
Kurt
made2cut is offline
This Thread is more than 1583 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
