'70 Wagon Build Thread* - Page 3 - Chevelle Tech
 6Likes
post #31 of 104 (permalink) Old May 23rd, 15, 8:07 PM Thread Starter
Bryan
Re: '70 Wagon Build Thread*
Here are some pics of the clearance between the steering gear and the pump.
1970 Chevelle Greenbrier Wagon 66 2/3% done
2013 Toyota Sequoia Platinum
Build Threads:
1969 6.0 Firebird (sold)
Any thoughts on why my front bumper had the Monte Carlo style parking lamps?
Sprech is offline
post #32 of 104 (permalink) Old May 26th, 15, 2:04 PM Thread Starter
Bryan
I ordered a few things from tanks inc this morning, but I think I'm most excited about this piece, and I hope it works.
http://www.tanksinc.com/index.cfm/pa...rod/prd107.htm
Build Threads:
Sprech is offline
post #33 of 104 (permalink) Old May 27th, 15, 10:51 PM Thread Starter
Bryan
Fuel Related
AC Delco EP 381electric fuel pump
AC Delco FP51 electric fuel pump harness
AC Delco TS7 strainer
Push Through Fuel Cap - Tanks Inc: p/n PTCK
6 Hole Bolt-in Pickup Kit - Tanks Inc: p/n 3tr, 3g-n, nbo, 6HPT
PA Series Pump Weld In Recess - Tanks Inc.: p/n PA-REC; If my tank guy can put this in and make it feasible to use, then I will likely go this route. You can extend the PA Series Pump assembly to the needed height, which in this case, I'm going to need about 22" of depth. If it's too cost prohibitive or cannot otherwise be done, I'll do with the aforementioned 6 hole bolt-in pickup. Was hoping to have the Tanks Inc. stuff for the weekend and when I asked yesterday if it would be shipped yesterday, I was told that it would, but apparently there was some miscommunication on their part and I likely won't be getting it until next week some time.
Build Threads:
Sprech is offline
post #34 of 104 (permalink) Old May 31st, 15, 12:14 AM Thread Starter
Bryan
Here are some pics of the radiator with the fans on. The mechanical fan is still on the L96 which will be coming off in the next couple of days. The factory upper rad support fits fine. I will probably get some foam or rubber to set in the top of the support. I either need to drill a hole in the bottom of the support or cut off a the mounting piece in the lower right corner of this stock photo as the fill is right on the hood with no room for the rad cap.
Spectra Premium CU1486 98-02 F-body radiator
You can see that the radiator fill is right on the hood. With the removal of that tab or the modification of the lower core support, this will drop about an inch.
Build Threads:
Sprech is offline
post #35 of 104 (permalink) Old May 31st, 15, 12:14 AM Thread Starter
Bryan
Here are some additional pics of the Hooker 8501-HKRs installed. I was hoping to use the van manifolds for the economic aspect, but no dice.
Lots of clearance for the brake distribution and lines.
You can see how it's hitting the heat shield for the starter. I think the factory van manifold would work fine here.
Build Threads:
Sprech is offline
post #36 of 104 (permalink) Old Jun 7th, 15, 9:08 PM Thread Starter
Bryan
Made some progress today. Completely stripped the frame of everything, getting it ready to media blast it and then paint it with Summit chassis epoxy paint.
See something wrong here?
Build Threads:
Sprech is offline
post #37 of 104 (permalink) Old Jun 7th, 15, 9:36 PM
I have a pair of control arms that look just like those. Must be a wagon only thing
63 Nova wagon
Philip is offline
post #38 of 104 (permalink) Old Jun 7th, 15, 9:37 PM
Do yourself a favor and weld nuts on the frame for the rear upper shock mounts.
63 Nova wagon
Philip is offline
post #39 of 104 (permalink) Old Jun 7th, 15, 10:18 PM Thread Starter
Bryan
Not a bad idea, I had to wait until the body was separated to get them off. I suppose I could have messed with it, but I knew the body was coming off.
Any suggestions on blast media?
Build Threads:
Sprech is offline
post #40 of 104 (permalink) Old Jun 7th, 15, 11:09 PM
I used Black Beauty, it is ground coal slag. Tractor Supply sells it as Black Diamond. I use the fine grit. Worked good on the frame.
63 Nova wagon
Philip is offline
post #41 of 104 (permalink) Old Jun 8th, 15, 2:14 AM Thread Starter
Bryan
The bags of coal slag at HF were busted and leaking. I picked up medium and fine walnut shell as well as medium glass. I'm going to do the frame and the undercarriage of the body. Not sure what I'm going to do, but leaning towards Raptorliner for the undercarriage and lizard skin sound and solar for the inside.
Build Threads:
Sprech is offline
post #42 of 104 (permalink) Old Jun 11th, 15, 10:42 PM Thread Starter
Bryan
A small update. I bought a Harbor Freight media blaster, the 100b model. Took me an hour to almost strip one of the rear upper a arms. The line kept plugging. After watching a few videos, I saw a guy that had one and he had to keep shaking it. I figured what was happening was that the media was feeding good for about 10 seconds and then if I opened the valve up, it would avalanche in and then plug the hose, so the video kind of confirmed that for me.
I got a good deal on 2 Boyd JYD's with tires; 17x8 with 4.5" BS and tires as well as a non-op SS hood. They are actually coming from the prison that is doing the Firebird, so they stuck them on and took pics for me.
17x8 w/4.5 BS Boyd JYDs.
I also picked up the lower 98-02 F-body radiator insulators. p/n's 1027-8679 and 10188023.
Build Threads:
Sprech is offline
post #43 of 104 (permalink) Old Jun 16th, 15, 12:07 AM Thread Starter
Bryan
Got suspension and steering stuff ordered today. To go with the Jeep Grand Cherokee box.
Centerlink - Moog DS749
P-S-T Polygraphite Super Front End Kit: p/n FEKSPBUI664
Bilstein Rear Shocks: p/n F4BE5E250M0 (f.k.a. AK1044)
UMI rear control arm kit: p/n ABR813 (added adjustable upper control arms)
UMI 1.25" front sway bar: p/n 4035
QA1 GE401-450B front coil overs as well as thrust bearings and wrench
UMI rear springs at factory ride height: p/n 4049R
Up next is to have the rearend rebuilt and should have a roller by the end of next weekend.
Build Threads:
Sprech is offline
post #44 of 104 (permalink) Old Jun 16th, 15, 11:08 AM
Rod
Your local prison has a body shop?
Thanks for detailing the parts selection. Could come in handy for some of us down the road, especially if you get a chance to let us know how the parts work out.
Rmchevelle is offline
post #45 of 104 (permalink) Old Jun 16th, 15, 2:56 PM Thread Starter
Bryan
They do indeed. It's the minimum security portion of the prison out at Indian Springs. They do pretty good work and they have a pretty good labor rate. They aren't that great at taking pictures or even getting them to you, but it's a small price to pay.
Build Threads:
Sprech is offline
