1970 Chevelle Wagon fuel tank - Chevelle Tech
 3Likes
post #1 of 32 (permalink) Old Apr 29th, 14, 2:07 PM Thread Starter
Hi, I'm a new member. I've searched and read the older threads on this topic. I need a fuel tank for a 1970 Chevelle Wagon (I do not have an old one to repair). Are any being made, any alternative options, and/or does anyone have one available?
1970ChevelleWagon is offline
post #2 of 32 (permalink) Old Apr 29th, 14, 3:49 PM
"Wild Bill"
Re: 1970 Chevelle Wagon fuel tank
Not being produced as far as I know.
You'll need to find one from a donor if possible.
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #3 of 32 (permalink) Old Apr 30th, 14, 2:55 PM
There is a guy in North Carolina (I think) that makes Aluminum ones. You send him the old one and he makes you a new one. I thought about it until he said starting at $1500. BUT its an option.
skongolf is offline
post #4 of 32 (permalink) Old Apr 30th, 14, 8:28 PM
Start looking for a 68-72- G.M.--" A " body Wagon. I guess this would be your best option.
Robinls5 is offline
post #5 of 32 (permalink) Old May 1st, 14, 5:36 PM
from what I have seen and done, as Bob said the wagon tanks from 68-72 are all the same, except from my experience, the tanks from "glass roof" wagons (Olds Vista Cruisers and Buick Sport Wagons) are a little different in size and shape. I have not tried a VC tank in my wagon, but it is different enough to see it by eye.
Good luck,
"Just remember, your last car is always a station wagon." chaos10meter, on The H.A.M.B.
chevygod is offline
post #6 of 32 (permalink) Old May 2nd, 14, 6:30 PM
Gossamer (Mike)
myself, next year I'm gonna cut out my rusted tool well and put in an El Camino gas tank.
Will mount in with no problems. Filler tube will need slight modification but El Camino tanks and sending units are produced, so easier to maintain.
lkmarsh likes this.
My version of the never made '72 SS454 Chevelle Wagon.
454 ATK Engine/550 HP/575 TQ/4.10
gear/T-350 trans./3400 ATI conv/B&M Comp. Shifter/ 1/4 ET-12.39 @108mph - 1.69 60ft.
"Bet I can get to the Grocery Store and back Home first!"
Gossamer454 is offline
post #7 of 32 (permalink) Old May 2nd, 14, 6:43 PM
Had posted this else where in a tank discussion, but if you do use the Elco tank in a 68-72, look at the filler/vent tube assemblies used on Chevy/GMC G-Vans (early 70's-95?) and Chevy Suburbans (73-early 90's). These use a long vertical tube with a bend connected to a horizontal tube that leads to the tank. All connected by short lengths of rubber hose. May be more easily adapted than trying to make from scratch.
chevygod is offline
post #8 of 32 (permalink) Old May 4th, 14, 4:26 PM
Gossamer (Mike)
I'll check that out, thanks.
post #9 of 32 (permalink) Old May 4th, 14, 5:26 PM
"Wild Bill"
Elky tank wouldn't fit on a 3 seat wagon obviously but is a solution on the 6 pass ones.
Really would like to see someplace start producing gas tanks for these cars...wagon popularity is growing.
post #10 of 32 (permalink) Old May 4th, 14, 6:35 PM
it makes sense to repop them as the tank would fit 5 years and 4 carlines. Figure out the diff's between the flat-roof tans and the Vista tanks, make them common, and the number grows again.
chevygod is offline
post #11 of 32 (permalink) Old May 4th, 14, 8:07 PM
Rich
Perhaps a solution, but not an easy one. The gasoline filler doors on the wagon and the pick-em up are in totally different locations. It would take some creative plumbing to modify the Elky filler neck to match up with the wagon filler door and possibly some sheet metal work to accommodate the filler neck modification. Also, fuel line(s) would have to be rerouted along with sending unit wiring. But then, if you are going to go to those lengths out of necessity, I suppose it would even be worth considering eliminating the foot well on a 3 seat wagon to accommodate the Elky tank.
A company by the name of Street Rods By Michael, Inc. claims to carry gas tanks for 64-67 wagons. www.srbymichael.com If they have them, perhaps others carry them as well. I don't know the differences between the earlier tanks and the later tanks but perhaps reworking 64-67 tank to fit in a later model might be easier than trying to make an Elky tank do the job.
Rich
Big White is offline
post #12 of 32 (permalink) Old May 5th, 14, 12:19 PM
If you're going to modify for flat tank why wouldn't you just use license plate location for filler? I was lucky that the tank in my '68 was in excellent shape, but I still cleaned and sealed it.
69 Malibu 307/350
55 210 Post 350/700R (My First Car)
72 Chevy G20 Sport van, 350/350 turbo
1968 GMC 3/4 ton pick up, 327/400 turbo
blue55 is offline
post #13 of 32 (permalink) Old May 14th, 14, 7:23 PM
leroy
I got a buddy parting a 70 wagon
autumn gold 70 is offline
post #14 of 32 (permalink) Old May 17th, 14, 5:58 PM
Gossamer (Mike)
The El Camino tank will be an easy fit. The gas filler tube isn't gonna be that big of an obstacle and the sending unit won't be much of a problem either. El Camino sending unit wired up and routed to current wiring setup. The fuel line will use the same route as El Caminos do as well as the tank mounting exactly in the same location as it would in an El Camino....easy peezy.
The most difficult job will be cutting out my rusted tool well and welding back in a nice flat panel.
post #15 of 32 (permalink) Old May 18th, 14, 12:21 AM
Look into getting the rear bed floor from a parted Elco. Then you would have the correct supports and strap mounts for the tank as well as the ribbed bed floor to replace the well area.
chevygod is offline
