Project Greenbrier - Page 6 - Chevelle Tech
 44Likes
post #76 of 339 (permalink) Old Nov 3rd, 13, 12:20 PM Thread Starter
Re: Project Greenbrier
Originally Posted by Philip View Post
Nice work, what did you use for the return? Looks like it has the end for a hose/clamp attachment.
Phillip, I used a piece of factory GM hard vapor line from the front of a GMC light duty truck where it leaves the vapor canister hose and mounts to the frame...
I thought it would lend a more "factory" look to my finished project...(I know, I know, nobody can see it anyway...but I will know.)
Also, it was the only piece of mandrel bent pipe in 5/16th's I could find in the shop when I decided to do this...
I like the way you did the punch idea in the hole for more surface area...my pipe was bent at a 45* angle so that wouldn't really work for me...I brazed mine, so it didn't look as good as yours when I was done...(there's really no way to test my seal, so I applied Right-Stuff to the outside of my pipes to assure a total seal.)
72 Greenbrier is offline
post #77 of 339 (permalink) Old Nov 4th, 13, 6:41 PM
Looking good. Still waiting to see how the final gas tank set up works. I am looking at an LS3 with a 6spd out of a wrecked 2010 Camaro now. Oh the decisions!!
skongolf is offline
post #78 of 339 (permalink) Old Nov 4th, 13, 6:44 PM
Originally Posted by 72 Greenbrier View Post
Worked on the fuel system a little more today...modified my pickup/sender assembly...
I wasn't lucky enough to have a pickup assy with 2 pipes in it...so I modified mine like Phillip did...
5/16th's hole drilled and elongated...
Needed to remove the end of the supply line tube so it can accept the Swagelok 37* AN fitting...
Swagelok stainless steel fitting...
"Special" holding fixture to keep everything in line before brazing...
Semi finished project...(I'm going to run my lines through the "hole" that the sender wire came through.)
When you say lines through the sender hole, what lines are you talking about? Also did you figure out the strainer issue on your pump?
skongolf is offline
post #79 of 339 (permalink) Old Nov 4th, 13, 8:50 PM
The lines would be the wires to power the pump and to the gas gauge.
63 Nova wagon
Philip is offline
post #80 of 339 (permalink) Old Nov 5th, 13, 10:58 AM
Gotcha. Thats what i figured after I posted. Really looking forward to seeing how it runs so I know what to do when I start mine.
skongolf is offline
post #81 of 339 (permalink) Old Nov 6th, 13, 11:48 AM Thread Starter
Yep...Phillip is correct.
Should have the pump and strainer in this weekend, (the whole tank end of this buttoned up), and hopefully most of the lines ran...
post #82 of 339 (permalink) Old Nov 18th, 13, 11:35 PM Thread Starter
Got the pump hung and wired up...
In we go...
And we are in...
Grommet and wires...
post #83 of 339 (permalink) Old Nov 19th, 13, 9:35 PM
Mike that turned out excellent. It will be copied on my wagon when it comes time for a pump install.
63 Nova wagon
Philip is offline
post #84 of 339 (permalink) Old Nov 22nd, 13, 1:29 PM
That is nice! Fly out to AZ and do mine for me!
skongolf is offline
post #85 of 339 (permalink) Old Nov 22nd, 13, 1:56 PM
Steve we can do ours together, just bring the tank and parts down to Marana. Already did the Nova, the wagon tanks look to be easier.
63 Nova wagon
Philip is offline
post #86 of 339 (permalink) Old Nov 22nd, 13, 4:57 PM Thread Starter
Thanks...it took me a lot more time to convince myself it could be done...and a LOT more time on different mockups...than it did to actually fab It up once I had it the way I wanted it.
Oh man, I'd love to...!!!
It was 7* outside the other morning when I went out to feed cows...
I could soak up some AZ weather!
(If you have time, I would take up Phillip's offer to help...from what I've seen him post...he has excellent fab skills and plenty of talent.)
post #87 of 339 (permalink) Old Nov 22nd, 13, 6:12 PM
It is only in 62° today because of the rain. But by mid week the 75° temps will be back
Thanks for the kind words.
63 Nova wagon
Philip is offline
post #88 of 339 (permalink) Old Nov 22nd, 13, 7:42 PM
I may take you up on that if I ever get a free weekend. Starting to line up parts now. Still have to get a motor first. May be getting the trans next week.
skongolf is offline
post #89 of 339 (permalink) Old Nov 23rd, 13, 11:30 PM Thread Starter
SLOWLY making progress...
got the power steering worked out today...used the factory hose for the 72 Chevelle...NAPA part #NPS 71619...$18.81
Shot from the bottom...
Top...had to bend the hard line a little right before it connects to the hose to clear the pressure port on the sector.
I apologize for the "bundle of snakes" look of my lines...I should have left the return line off, but I didn't want to leak fluid all over. The plan is to run a PS cooler eventually.
I'll get some better pics from the front tomorrow.
post #90 of 339 (permalink) Old Nov 30th, 13, 11:16 PM Thread Starter
Fuel filter mounted...hard line ran to back of frame...
Tank plumbed...
Goin' in...
Lines ran...
And tank protector in...
