elko frame for wagon - Chevelle Tech
 6Likes
  • 1 Post By NickeyChevelle
  • 1 Post By hydro462
  • 2 Post By Robinls5
  • 1 Post By chevelle-427
  • 1 Post By Philip
post #1 of 10 (permalink) Old Nov 6th, 19, 4:52 PM Thread Starter
mjc
mike
Just to confirm a 1969 to 72 el camino will work in my 1972 Nomad wagon? I can get a factory bowed frame that way.
mjc is offline
post #2 of 10 (permalink) Old Nov 6th, 19, 5:19 PM
Bruce
Re: elko frame for wagon
Yes. A 1968 through 1972 El Camino frame will fit, however there may be minor differences in locations of screw holes for Brake Lines and/or Fuel Lines depending upon the model year of the frame.
71350SS likes this.
Our You Tube Vids:
NickeyChevelle is offline
post #3 of 10 (permalink) Old Nov 6th, 19, 6:31 PM
Ask Philip.............he has an El Camino frame under his 72 wagon, I think.
66 Malibu
busterwivell is offline
post #4 of 10 (permalink) Old Nov 6th, 19, 6:40 PM Thread Starter
mjc
mike
Thats true lines go inside the C on the non boxed frame. I want to build a frame with some handling parts and this seems like an easier way and get the stiffer frame at the same time.
mjc is offline
post #5 of 10 (permalink) Old Nov 7th, 19, 7:21 AM
The 68 to 72 el Camino frame is called the #1942 frame. As far as I can tell, it was only used on 68 to 72 el Caminos and the 69 to 72 Pontiac Grand Prix..
When I bought my 69 el Camino and was taking it for a test drive, I immediately noticed how well it handled and how sure footed it felt over the other A bodys I've driven, even with a worn out suspension, brakes and tires..
Your making a good choice putting that frame under your wagon.. Its very strong..
the heckler likes this.
hydro462 is offline
post #6 of 10 (permalink) Old Nov 7th, 19, 4:11 PM
As Buster says, check with Philip. He did that swap and would know the details.
JWagner is offline
post #7 of 10 (permalink) Old Nov 7th, 19, 4:15 PM
I have a 1970 El Camino and a 70 wagon. If you get a Wgn. / El Camino Frame,,,, Make sure you get the transmission CROSSMEMBER. WHY? My 70 El Camino had the brackets for the M-22 shifter. Over the years of ownership( 50 this coming march) I stuck a Hurst shifter in it.
Some of the crossmember brackets were not like they left the factory, Due to me with a blue wrench and a hammer. Looking for the El Camino/ Wgn. crossmember with the stock factory mounts, or just a STOCK Auto. Crossmember may cause your blood pressure to rise quite a bit.
The tranny crossmember fits= Wagons & El Caminos !
If push comes to shove, I have one.
NickeyChevelle and 71350SS like this.
Robinls5 is offline
post #8 of 10 (permalink) Old Nov 8th, 19, 10:28 PM
It will fit, it will be stronger as its wider in middle use a shorter cross member.
And for others here a 64 to 67 4 door chevelle frame will also fit a 2 door.
We slid one under a 66 chevelle
Sent from my SM-G935V using Tapatalk
71350SS likes this.
chevelle-427 is offline
post #9 of 10 (permalink) Old Dec 9th, 19, 11:23 AM
wagons rule!
Pete
Location: In the Beautiful mountains of western North Carolina
Got one under my 70.
details on this page, click this link
chevelle wagons parts 1970 71 72 GM a body nomad concours greenbrier estate
btw FO_FDYFO is ebonics for four fifty four.
Web Master,
wagon parts and info only at
FO_FDYFO is offline
post #10 of 10 (permalink) Old Dec 9th, 19, 4:25 PM
Yes it fits perfectly, wanted to build the frame with the fuel and brake lines as well as drive train before taking the wagon off the road. It was the only frame I could find at the time but I'm happy with the extra stiffness under the car.
LeoP likes this.
63 Nova wagon
Philip is offline
