65 wagon parts interchange - Chevelle Tech
post #1 of 6 (permalink) Old Dec 14th, 18, 2:11 PM Thread Starter
Hi wagon guys I'm looking for two sheetmetal covers that go on top of the cargo area floor just behind the folding rear seat I don't see them in the body service manual so not sure what they are called. What I'm wanting to know is what years are the same for the folding rear seat and also the 2 cover pieces is it 64-67 or 64-65 thanks
tommy411 is offline
post #2 of 6 (permalink) Old Dec 14th, 18, 6:42 PM
Rich
Re: 65 wagon parts interchange
64-65 would look the same (I think) and 64-67 would all be functionally the same. I think they changed the pattern pressed into the metal for 66-67. I could be wrong about the pattern in the metal since it has been a long time since I've seen inside a 66-67 wagon.
I may have a spare one from a 65, if that would be of any help to you shoot me a PM.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is online now
post #3 of 6 (permalink) Old Dec 16th, 18, 3:53 AM Thread Starter
Thanks for the reply and info Rich I will contact you.
tommy411 is offline
post #4 of 6 (permalink) Old Dec 23rd, 18, 10:48 PM Thread Starter
Hi guys had a little trouble posting pictures I guess I was making it too difficult. Both my cars are missing these pieces so refresh my memory which pcs. are they? I also put a picture of my window drain which involved a copper fitting and orig type J B Weld. Does anyone know of a supplier for the door handle mechanism I see 67 but not 65 ?
ID:	581422   Click image for larger version
ID:	581424   Click image for larger version
tommy411 is offline
post #5 of 6 (permalink) Old Feb 16th, 19, 1:56 PM
Gary
Smile Re: 65 wagon parts interchange
The parts you need are the same on two and four door wagons but need to be 64 65 as they change on 66 67.
You can't break it if it's broke to start with
saltygog is offline
post #6 of 6 (permalink) Old Apr 5th, 19, 7:47 PM
Al
The larger piece is called the “Rear Compartment Floor Panel (at kick-up)”. The smaller piece goes on the vertical metal piece behind the rear seat bottom to protect the wiring that goes across on the way to the tail lights, don’t know what it is called. See page 2H-14 in the body service manual.
bezoar is offline
