'72 Greenbrier Wagon Project - Page 5 - Chevelle Tech
 48Likes
post #61 of 106 (permalink) Old May 26th, 18, 9:50 PM Thread Starter
George
Re: '72 Greenbrier Wagon Project
Originally Posted by mjc View Post
i have been reading all this since I just picked up a 72 Nomad. Have any of you looked at the springs Speedway Motors sells for stock cars? they have lots a different spring rates.
Congrats on the Nomad!
I havent checked them for springs. The moog site has alot to choose from as well. Lots to sort thru!
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #62 of 106 (permalink) Old May 28th, 18, 2:00 AM Thread Starter
George
Okay, left the wagon sit on all 4’s over nite to look at it with fresh eyes. Took some measurements.
Dr fr...28-1/8 Pass fr...28-3/4
Dr rear... 25-1/5. Pass rear....26
Still have the 1” spacer in the rear. Thought I would shoot for the fender lip at the top of the tire for now. Just in case they decide to settle.
Started with the pass side front wanting to drop 1-3/4” so I took it down 7/8”. Orig height was 15-1/2”. Ended up cutting just about one coil.
Drivers side wanted to drop it 1-1/8” so took it down 9/16”. Original height was 15-5/8”. Ended up cutting about 3/4th a coil.
After getting it back together with all the control arms loose and bouncing the front end a bunch, here is where it landed....
Dr fr....26-3/4” Pass fr.....27”
Dr rear 25-7/8 Pass rear...25-3/4
Still have the rear spacer in the dr rear. It looks much better to me now. Also not as spongy feeling, but not harsh / stiff. I guess with the aluminum intake, headers, aluminum radiator and no a/c stuff was enough weight out to make the front end crazy high. With plans for aluminum heads/ water pump down the road, would make it higher still.
Ended up ordering all new UMI rear control arms / frame braces instead of messing with the old stuff. Works well on the 71.
ID:	558537   Click image for larger version
ID:	558545   Click image for larger version
'71 Malibu
Geo71 is offline
post #63 of 106 (permalink) Old Jul 2nd, 18, 3:27 PM
wagons rule!
Pete
Location: In the Beautiful mountains of western North Carolina
what rear springs do you have? that height looks good.
MarkP likes this.
btw FO_FDYFO is ebonics for four fifty four.
Web Master,
wagon parts and info only at
FO_FDYFO is offline
post #64 of 106 (permalink) Old Jul 4th, 18, 12:54 PM Thread Starter
George
The rears are Napa 2771962 HD springs. Bought them originally for the 71, but they sat way too high. I like the stance, not sure if they will be enough for a load in the back. Always coukd put some air in the shocks.
Also still has the 1” spacer in the drivers rear....
'71 Malibu
Geo71 is offline
post #65 of 106 (permalink) Old Jul 4th, 18, 1:27 PM
wagons rule!
Pete
thanks. I will try them. why do you think you need a spacer on one side, why is the car sitting leaning without it?
Web Master,
FO_FDYFO is offline
post #66 of 106 (permalink) Old Jul 4th, 18, 5:55 PM Thread Starter
George
When I first got this, noticed the pass side sat much higher front and rear. Phillip said his was the same. Ive seen pics of others and they also appear to sit higher. I coukdnt see anything bent/ worn etc. still has orig body mounts, but dont look bad.
The spacer made it close enough to even. Also trimming abit more in the pass front vs drivers front evened out the front.
Maybe its due to the gas tank being on the drivers side and no spare tire/ jack in pass side? Also the a/c stuff being removed may have something to do with it?
Does yours sit level?
'71 Malibu
Geo71 is offline
post #67 of 106 (permalink) Old Jul 4th, 18, 8:27 PM
wagons rule!
Pete
yes, all of my wagons have always sat level without spacers. and I have had too many to count
Web Master,
FO_FDYFO is offline
post #68 of 106 (permalink) Old Jul 4th, 18, 11:10 PM Thread Starter
George
Interesting. First I thought the front springs weren’t seated in the pockets correctly. Removed and replaced them with no real difference. It doesnt appear to have been wrecked or taken apart at any time.
I see alot of them in pics that look higher on one side.
Its all good now though.
'71 Malibu
Geo71 is offline
post #69 of 106 (permalink) Old Jul 6th, 18, 12:15 AM
Hey George thought I would update my spring situation. Installed bigger wheels and tires and had a rub issue in the front. Installed big block wagon springs and the issue went away. Sits a little higher, about an inch, but the ride is so much better. No more floating.
63 Nova wagon
Philip is offline
post #70 of 106 (permalink) Old Jul 7th, 18, 9:44 PM Thread Starter
George
Nice Phillip! Which ones did you use? Still keep the spacers?
Mine is just about ready for some road testing. Had to take the intake off and have it planed. It was warped and not sealing a couple cylinders. Fixed a bit of wiring too.
Getting closer anyway!
LeoP likes this.
'71 Malibu
Geo71 is offline
post #71 of 106 (permalink) Old Jul 9th, 18, 6:47 PM Thread Starter
George
Ok got the front suspension, springs done....fixed up some underhood wiring bugs that needed attention....fixed the engine smoking/ rich smelling issue by getting the intake manifold surfaced (it was warped) and new intake gaskets. Car starts super easy, cool and not stinky anymore!
Next up is to fix the front seat bottom....I'm not sure what it is I need. Noone has any "wagon" seat covers and seat foam listed? Where should I be looking?
'71 Malibu
Geo71 is offline
post #72 of 106 (permalink) Old Jul 10th, 18, 10:36 AM
Hinshaw's
Geo71 likes this.
66 Malibu
busterwivell is offline
post #73 of 106 (permalink) Old Jul 10th, 18, 12:23 PM Thread Starter
George
Originally Posted by busterwivell View Post
Hinshaw's
Thanks, will give them a look..
'71 Malibu
Geo71 is offline
post #74 of 106 (permalink) Old Jul 10th, 18, 7:51 PM
Moog 5536, yes kept the spacers.
Geo71 likes this.
63 Nova wagon
Philip is offline
post #75 of 106 (permalink) Old Jul 15th, 18, 5:54 PM Thread Starter
George
Finally got to take a short drive! Had an issue with it spitting and sputtering driving down the road. Idle down the drive it was fine. Putting the pedal down a bit, it would miss and sputter terrible. Ended up being something to do with the vac advance. Unhooked and capped it off and all was fine. Either hose is bad or advance is bad.
Driving it was ok. Pretty floaty still. Also a bit fumey. Need to find out where the tailpipes are supposed to exit. These are right behind the rear wheels but under the car on each side.
Was fun going for a drive!
'71 Malibu
Geo71 is offline
