Paulie's 69 El Camino build - Page 5 - Chevelle Tech
El Caminos El Camino & Sprint
 85Likes
post #61 of 316 (permalink) Old Oct 27th, 13, 10:30 PM Thread Starter
Paulie
Re: Paulie's 69 El Camino build
Hi guys, got some photos now, I called Jegs, Summit and CPP and emailed a couple of places; nobody could steer me straight on what to do for front coil-over springs, but a couple did say to check with RideTech. Called and emailed RideTech and kinda got me there, so I called and emailed Hyperco. They set me straight, and then RideTech confirmed them when they did finally answer.
So for the shocks, I went with coil-overs by Afco #3840F/BNC
and the springs are HyperCoils 2.5"x10" @ 750lb.
Name:	Copy of 0912131949.jpg
ID:	120577   Click image for larger version
Name:	Copy of IMG_0006.JPG
Paulie
BigBlockPaulie is offline
post #62 of 316 (permalink) Old Oct 27th, 13, 10:36 PM Thread Starter
Paulie
I bought Wilwood CPB calipers and brackets and it wasn't worth the backflips I'd be doing to make them fit, so went to CPP for there cailper with E-brake.
Finally something fit without any issues; isn't that refreshing???
Name:	Copy of IMG_0043.JPG
ID:	120593   Click image for larger version
Name:	Copy of 1019131210.jpg
Paulie
post #63 of 316 (permalink) Old Oct 29th, 13, 5:32 AM Thread Starter
Paulie
Here, after I had cleaned up and painted the missing stock arm areas, I am putting on the new upper arms. Later after a four lb. hammer adj. I could get the new lower arms to go in. Finally starting to look like something; little by little.
ID:	120961   Click image for larger version
Name:	Copy of IMG_0013.JPG
Paulie
post #64 of 316 (permalink) Old Nov 2nd, 13, 7:40 AM
Ray
Looking very nice
70 SS Chevelle Van Nuys Cal Built
shadowgray396 is offline
post #65 of 316 (permalink) Old Nov 3rd, 13, 9:33 AM Thread Starter
Paulie
Red face Re: Paulie's 69 El Camino build
Ray, thank you so much, looking at your frame pictures and the pressure washing; it put such a big smile on my face because you've traveled my road and know where I'm at don't you?
Wow what a job you've done, and all that you went through too, even down to seat frames, etc.
I really can appreciate your 70, amazing job Ray
Building my car is lonely in that there's no car buddies around to relate.
I just keep posting, thank you all for your support!
Paulie
post #66 of 316 (permalink) Old Nov 3rd, 13, 9:46 AM Thread Starter
Paulie
Here's two shots of last nights efforts, I got the shocks and spindles on.
The top arm just touches the frame at full drop, but I'll see how it is after it's aligned and fully completed.
Name:	Copy of IMG_0088.JPG
ID:	122034   Click image for larger version
Name:	Copy of IMG_0100.jpg
Paulie
post #67 of 316 (permalink) Old Nov 15th, 13, 7:13 PM Thread Starter
Paulie
I just ordered 2 Howe extended lower ball joints from Mark at SC & C, nice guy. Maybe that will be enough get the top arm to not touch the frame. So that's 1.5" taller now, a half inch from the top arm spacers, but I'm wondering if you count that. A 1/2" tall upper and a 1/2" lower ball joint.
Paulie
post #68 of 316 (permalink) Old Nov 16th, 13, 10:19 PM
Ray
Thank you for your complements. I have traveled the road you are on. Keep posting so we can watch your progress and it also helps to keep you motivated to keep moving on. Looking forward to following your progress.
post #69 of 316 (permalink) Old Dec 23rd, 13, 11:08 PM Thread Starter
Paulie
Well, I got the ball joints and as everyone says, they are really nice. Talking with Marcus the spacers on the top arms don't count in the spindle height, so I am okay with an inch. Hope to add the front SS brake lines from RightStuff and run the rear Jegs SS lines over the holidays. I picked out a flat top master cylinder from Tuff Stuff but waiting on restock of #TFS 2024NC @ Pace in ohio. Still looking at line locks...
Paulie
post #70 of 316 (permalink) Old Mar 7th, 14, 7:34 PM Thread Starter
Paulie
Update cause works been busy, Got the Hurst line lock, got the chrome master cylinder after six weeks from Tuff Stuff, got the CPP chrome proporting valve and now the bracket from Wilwood with the little brake lines to it but I'll have the fit it up with adapters cause the line ends are the wrong size but that's all I could get, tried cpp, right stuff and ebay they must all source china crap cause it's all bad; either the brackets are poor or the lines are incorrect... lot of refunds and sorrys.
I took the lower arms back off the change the lower ball joints to the longer Howes joints and painted the spindles
Paulie
post #71 of 316 (permalink) Old Mar 8th, 14, 8:12 AM
Nick
Liking the progress and the updates, suspension looks great. Keep at it..
Shootstraight is offline
post #72 of 316 (permalink) Old Jun 22nd, 14, 8:12 PM Thread Starter
Paulie
Thanks Nick.
I just finished reading through the great -Jeep Box upgrade- https://www.chevelles.com/forums/show...light=jim+shea
And ordered the 95' JGC pump to add to the build. I was going to run a manual box for simplicity but this is a no brainer. Then I can get a March pulley set-up with a type II pump.
I haven't posted but been busy, I put on the rear brake kit that uses the caddy calipers with the E brake and it wouldn't fit inside my 15" rim. The 11" rotor and brackets would drag on the stock 14" rim as expected, but after adding the caliper and tried to put the rims on; surprise!! Mucho grinding
Paulie
post #73 of 316 (permalink) Old Jun 29th, 14, 11:52 AM Thread Starter
Paulie
I just pulled the old 60's box off, pretty straight forward. Gotta laugh; even after the hosing, pressure cleaning, sand blasting, I still found cactus/clay behind the gear box. (Road Kill Texas car)
Paulie
post #74 of 316 (permalink) Old Oct 19th, 14, 8:47 PM Thread Starter
Paulie
Hi, I haven't posted but have been working on the underside body now. This summer I finished the power steering. Last month I changed out the rear stainless brake line to the rear for a steel line. I couldn't flare that stainless. I welded a center mounting bracket to the rear frame for the stainless flex line. I mounted the brass T to the rear and made short hard lines out to the four link brackets. I welded tabs to each bracket and ran stainless flex lines out to each caliper. Boy am I glad that's done. Add a driveshaft and the frame is done.
Now it's body time, the inside floor looks great but the underside had the seams from the patch panels so I cut off the extra lip underneath as tight as I could, body hammered the tunnel and patch seams flat and used all metal body filler to clean it up. Doing good.
Paulie
post #75 of 316 (permalink) Old Dec 24th, 14, 10:19 AM
Jay
sweet build!
Elcoman is offline
