Paulie's 69 El Camino build - Page 3 - Chevelle Tech
El Caminos El Camino & Sprint
 85Likes
post #31 of 316 (permalink) Old May 30th, 12, 7:31 PM Thread Starter
Paulie
Re: Paulie's 69 El Camino build
Just a picture of the rear-end going back to the builder for final bracket welding. It seemed pretty heavy this time putting it in the trunk, I must be getting soft.
Paulie
BigBlockPaulie is offline
post #32 of 316 (permalink) Old Jun 16th, 12, 10:12 AM Thread Starter
Paulie
I brought the Dana 60 back and painted it aluminum rustoleum. The brackets are welded around the tube really nice now; take what you can't do to the pro's, it's money well spent. After the paint dries I'll try to reinstall the pig this weekend yet.
Paulie
post #33 of 316 (permalink) Old Jul 1st, 12, 10:12 PM Thread Starter
Paulie
Last weekend I put the rear end back in, and this weekend I cut square 1" stock to make a fuel cell bracket to hang the cell at the rear frame area.
I have a 15 gal. RCI cell and a bracket kit. The cell is well made but they must import the bracket kit because its skewed front to back when tighten on the tank; just how they bent it. It is level with the bottom edge of the frame but today I pulled out the roll-over vent and it sticks up a good 2 1/2"; so I'm gonna need to put spacers to lower the cell an inch to stay below the bed. (measure twice, cut once) The rear sump fittings just cleared the frames round crossbar nicely but now they'll be a inch lower than planned. I rolled the car outside to measure a rough length for a new fuel line but was soaked in five minutes with the outside heat. Gonna be an evening job.
Paulie
post #34 of 316 (permalink) Old Aug 23rd, 12, 4:51 PM Thread Starter
Paulie
Sorry nada too freakin hot
Paulie
post #35 of 316 (permalink) Old Aug 24th, 12, 9:43 AM
Tim
Paulie
Awsome project / Looks GREAT !
My wife and I have a 69 Big Block Camino too .
Can't wait to see the rest of the Elky come together.
Keep us in the loop
TimNY is offline
post #36 of 316 (permalink) Old Dec 12th, 12, 10:13 PM Thread Starter
Paulie
Added some pictures of the tunnel cut and extend, and the filler cap around the shifter area I formed.
Name:	Copy of El Camino resto 001.jpg
ID:	58719   Click image for larger version
Name:	Copy of El Camino resto 108.jpg
Paulie
post #37 of 316 (permalink) Old Dec 12th, 12, 10:29 PM Thread Starter
Paulie
Here's a picture of the headers added. Why are they always never easy
A my friend Bill helped me fit them to work with the head studs. We pre-lubed the motor well and spun it. The distributor is just posing, not set yet but looks good so far. Working on the exhaust now but will have to remake the cross member now. The header collectors ended up close to the cross-member and much wider. I bought a 3" s-bend set of pipes from flowmaster but then the mufflers don't line up with the rear exh. circles through the frame. I'm just trying to start it up before the years end and running into all the glitzes
Name:	Copy of El Camino resto 122.jpg
Paulie
post #38 of 316 (permalink) Old Dec 13th, 12, 7:11 AM
Nick
Keep at it Paulie, that's gonna be an awesome ride before long. I'm finding with mine that I'm enjoying the process so I don't have to be in such a rush. At first I was frustrated because I'm pretty goal driven but then I gave up on the goals and just enjoyed the moments and the build.
Shootstraight is offline
post #39 of 316 (permalink) Old Dec 30th, 12, 8:56 AM Thread Starter
Paulie
Thanks for the encouragement guys, I've been working alot and not much time for wrenching but have bought alot to get the
engine fired up; A box of AN fittings and hard lines, 3" exhaust pipes and super turbo mufflers, , MSD bushings and shims, all the little things you run into, so, I'm going to get moving pretty quickly soon. I wante to start it before years end but life butts in and clogs the flow of things. I'm encouraged about next year 2013.
Paulie
post #40 of 316 (permalink) Old Jan 20th, 13, 6:41 PM Thread Starter
Paulie
Well I've worked on the fuel lines and fittings and finished the supply and return lines to the cell. I found a use for a breather I had on a shelf for years on the roll over vent line: ha !
Name:	Frame Pictures 047.jpg
Paulie
post #41 of 316 (permalink) Old Jan 20th, 13, 9:02 PM Thread Starter
Paulie
I pulled off the passenger side header to heat tape the wires and boots. The drivers side fits great and the wires fit fine underneath; they are 2" Doug's headers but the passenger side is really tight and needed a beat down in several places being much tighter to the head and frame.
I wonder if Hooker comps or super comps fit any better on the right side? Anybody got a picture of them and how they fit?
I clocked the mini starter straight down and hooked up a bump switch to it(the car has no wiring). I added a junction block to run a hot wire up and connected the alternator. I'll get an Optima and mount it under the bed correctly later. I'm using short temporary cables and going to use my car battery just to fire it up. I want to hear it run; I've waited years.
Then I'll pull the body and detail the frame, add the brakes, get the Ram #80-2125N clutch and Denny's nitrous ready drive-shaft. That's this years goals.
Paulie
post #42 of 316 (permalink) Old Jan 26th, 13, 7:56 PM Thread Starter
Paulie
I just finished the shorty exhaust. It was easier to remake the cross-member than to contort 3" exhaust. I had Art Morrison bent one 7" wider than there ready made piece for my big block width. Works great now. It doesn't look like there's much to them, but they contour tight to the car and stop just through the rear frame holes at the four link for now. I'll add an H-pipe and run out the back later as well.
Name:	Copy of Engine 009.jpg
Paulie
post #43 of 316 (permalink) Old Feb 6th, 13, 9:41 PM Thread Starter
Paulie
It's alive
My superbowl sunday was in the driveway wrenching on my engine. Fired it up after eight years of patiently turning it like a bottle of wine.
Had a freeze plug seeping and two carb fuel drips. Fixed those and had to jump the distributor a tooth because of my vacuum can hitting the intake where she wanted to run. A shot of starting fluid and ran it, I felt like a young father again in the hospital babyroom. I stopped when the plastic oil line for the sender had enough heat.
Have no idea which team won; but I did Sunday!
Name:	El Camino resto 124.jpg
Paulie
post #44 of 316 (permalink) Old Feb 16th, 13, 1:12 PM Thread Starter
Paulie
I've been back and forth with Ram clutches and got their 80-2125N Dual clutch set-up. The N is the 900 series material I needed for the nitrous. Turns out the LS version of the T-56 I have uses a hydrallic throw-out #78160. Not sure what slave cylinder to get.
Paulie
post #45 of 316 (permalink) Old Feb 16th, 13, 7:19 PM
shane
cool deal! glad to see you making progress. makes it all worth the effort when it starts to come together.
Shane Doss
carfarmer is offline
