1972 Sweep dash Elcamino - Chevelle Tech
El Caminos El Camino & Sprint
post #1 of 3 (permalink) Old Nov 10th, 19, 9:58 PM Thread Starter
Where is the light that aluminates the actual speedometer in a sweep dash? and how do I get to it? Thanks
Mnordick is offline
post #2 of 3 (permalink) Old Nov 10th, 19, 10:12 PM
Re: 1972 Sweep dash Elcamino
There are many lamps in the back of the speedometer and idiot light assembly. It'll be easier but perhaps not completely easy to reach them all if you remove the vinyl dash cover. I'd replace as many as you can get to and it might also help to disconnect the speedo cable.
Use delicate caution here around the thin plastic circuit board. It'll be very easy to damage if it is not already damaged.
B52bombardier1 is offline
post #3 of 3 (permalink) Old Feb 12th, 20, 11:52 AM
Gale & his cats
Here is a link for you.
1970-72 sweep dash - Name the Idiot Lights
https://www.elcaminocentral.com/thre.../#post-2412633
The thread starts with the idiot lights and progresses through repairing a common power problem with the rear sweep lighting and a couple other electrical things for the dash.
Click the images for larger images.
Old Bear is offline
