Let's Talk LS Swap....Again. 70 Elc SS - Page 2 - Chevelle Tech
El Caminos El Camino & Sprint
 7Likes
post #16 of 17 (permalink) Old Nov 17th, 19, 10:22 AM
Hugh
Re: Let's Talk LS Swap....Again. 70 Elc SS
go for it...you won't regret. Plenty of them have been done. If you are on a tight budget, then look to buy a complete 6.0L set up with trans and accessories that has been converted to a 4 wire set up. This will be pre 2012, but will be a lower entry price. Plan on changing the pan to the holley 302 and just use the stock exhaust manifolds or switch to the camaro ls1 manifolds which flow well.
Plan on modifying the tunnel and probably the biggest hassle will be the power steering and the fuel system. Just send the money and buy a fuel tank and lines.
Good Luck!
Rucumn is offline
post #17 of 17 (permalink) Old Jan 14th, 20, 5:13 PM
Michael
First, a few LS swap truisms:
1 - It will cost you more than rebuilding what you have.
2 - It'll likely take you longer. It's a more complicated build.
Oh so true!
Thanks Rick
64 Chevelle
85 Monte Carlo SS
Mikes64 is offline
