Considering an LS swap - Page 2 - Chevelle Tech
El Caminos El Camino & Sprint
 10Likes
post #16 of 35 (permalink) Old Jul 13th, 19, 7:19 AM
Re: Considering an LS swap
Originally Posted by Hotwire View Post
You have any track times? Everyone's butt dyno isn't calibrated the same. 😉
I don't understand what good are track times on a street car.. A street car should be designed to climb hills without the need to build up revs, it also should be able to power torque deep turns, run smoothly and start easily... A compression of 9:1 is usually best for what I like..
A drag car should have max power in a short rpm range.. This doesn't work to well on the street were you need power right off idle..
My butt dyno seems to show more power to the car that carries it around the most.
hydro462 is offline
post #17 of 35 (permalink) Old Jul 13th, 19, 7:32 AM
Just collecting data. This thread is about considering an LS. A low compression 454 with 2.87 gears does raise an eyebrow as the stats aren't there and it does not sound like a ripper (no offense). Was just asking if you had any track times so I (or we as a directive group) could determine if this was an alternative to the LS platform.
*Jeff*
LQ4 / T56 Swap
Hotwire is offline
post #18 of 35 (permalink) Old Jul 15th, 19, 1:29 PM
You'll never regret the LS swap...
"LS swap without breaking the bank"
"Project Greenbrier" build thread...
72 Greenbrier is offline
post #19 of 35 (permalink) Old Jul 15th, 19, 6:18 PM
"Wild Bill"
Damn 255 Walbro in-tank pump took a dump today...2 hrs total run time.
Wired correctly thru a relay and in a baffled Tanks Inc tank.
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #20 of 35 (permalink) Old Jul 15th, 19, 7:25 PM
Originally Posted by BillsCamino View Post
Damn 255 Walbro in-tank pump took a dump today...2 hrs total run time.(
I got burned on a couple knock-off pumps...one Walbro, and a couple AC-Delco ep381's...Chinese or Jap origin when I finely go to the bottom of it. (All three boxed in perfectly printed "OE" looking boxes.)
Did yours come with the tank??
post #21 of 35 (permalink) Old Jul 15th, 19, 7:37 PM
"Wild Bill"
Could be.
Bought the complete kit...pump, gauge sending unit, regulator, hose, fittings, hangers, and tank... from Tanks Inc.
Thinking about simplifying things and install the Holley 12-300 into the stock tank.
post #22 of 35 (permalink) Old Jul 15th, 19, 7:44 PM
"Wild Bill"
And need to get that air filter moved into cooler air... 4" piping needed.
post #23 of 35 (permalink) Old Jul 15th, 19, 9:32 PM
Some fuel pumps aren't able to handle full time full voltage and current, they need PWM power. Check with the maker. Externally mounted in-line pumps will run hotter, more so if it's powered with full time full voltage and current.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #24 of 35 (permalink) Old Jul 15th, 19, 11:40 PM
No! Don't look into the light! LS motors are ugly and have no place in an old car. It's your car so do what you want, but there's nothing wrong with an old school BBC or SBC, or fuel injected old school.
'69 Camaro - 429 SBC Dart Iron Eagle 9.325" block, Crower crank, Crower 6" Billet rods, Ross pistons (10:1), Total Seal S/S rings, AFR 245 heads, T&D steel rockers, Cloyes Timing Set, 4-7 swap solid roller 274/286 @ .050", .704" lift, Dart single plane, Dominator EFI, Stef's #1705R pan, F2 Procharger on E85
Steve69SS396 is online now
post #25 of 35 (permalink) Old Jul 16th, 19, 1:27 AM
Originally Posted by steve69ss396 View Post
no! Ls motors are ugly and have no place in an old car.
lol!!!
Yeah, this perfectly executed swap is really hard on the eyes...
post #26 of 35 (permalink) Old Jul 16th, 19, 8:58 AM
"Wild Bill"
Yes, both Tanks Inc and FiTech have specific PWM setting recommendations for this combo.
Need to set PWM to 100, which I have.
I've got a new Tanks Inc pump being delivered today...a GPA-5.
Went up one size.
post #27 of 35 (permalink) Old Jul 16th, 19, 6:29 PM
Went up one size.
That Walbro pump should have held up, but stuff happens. I've been running a Walbro GSL-392 external inline pump just in front of my stock tank for going on 3 years. It does not run hot, it doesn't even run warm, and it is at 100% PWM, which equates to no PWM.
BTW - My external pump has Made in USA stamped into the case. I guess knock offs could do the same, but I don't know. Bought 2 of them from Summit. One is sitting in the box in a tool bag behind the passenger's seat of my sled. Still waiting for the other one to fail. Knock on aluminum.
Best of luck with the new pump.
Forgot to add. I'm too lazy to do a LS swap, and I've thought about every time I pull the 350 out to work on it. Last time I pulled the front end off, and that would have been the perfect time, but talked myself out of it, and put a retro roller, and some new bearings in the ole gen 1. The gen 1 5.7 makes enough tire smoke to satisfy me. Racing and getting time slips is not in the cards. Maybe 30 years ago, not now though. My eye sight and reaction times were a lot better 30 years ago.
BillsCamino likes this.
'65 Chev El Camino
SBC350/Maybe 400HP @ crank, 700R4
Edelbrock Pro-Flo 4 4150 MPFI
'67 P-11 Norton
Schwany is offline
post #28 of 35 (permalink) Old Aug 30th, 19, 10:20 AM
a stock high miles 5.3 isnt anything Id spend a lot of money on and 290hp wont feel the least bit impressive, something to think about.
think about it...150k miles is the min most these truck motors will ahve on them that is a TON of miles
Mine has 186k and still runs smooth but compared to new? shes tired
If you want a reliable 350-400hp that is so easily done with a modern head/roller cam these days.
HEI, mech fuel pump its foolproof. Some of the new carbs out are pretty much set and forget
cuisinartvette is offline
post #29 of 35 (permalink) Old Aug 30th, 19, 12:44 PM
George
A bunch of my racing buddies run these.
Mid 80's Cutlass...stock other than swapped cam and valve springs, small [email protected] Motor has 255K on it.
S10 Blazer stock with cam, valvesprings and running a carb small turbo....9.85 not sure on the mph Neither one of these are turned up very much.
With the new Holley Terminator X setup, now they are literally plug and play. No more stock computer reprogramming and harness rewiring....I may pull the 454 out of the wagon over the winter and swap.
Already have a "built" 6.0 waiting to swap in the 71 that I race...gonna run a carb and nitrous on it. Mostly stock parts other than cam. springs and pistons.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #30 of 35 (permalink) Old Aug 30th, 19, 12:48 PM
George
150K on one of these is not much at all....I know its crazy, but my buddies all look for the 250-300k mile motors...I couldnt do it, rebuilt the one I bought, mostly stock parts though...should be about 500hp I'm told. We shall see....
'71 Malibu
Geo71 is offline
can chevelle and el camino windshields swap? mad hooker Chevelle Tech 9 Jun 23rd, 14 12:32 AM
Muncie swap questions sam72 Transmission & Driveline 8 Jun 20th, 14 8:49 PM
NE Georgia Swap Meet, June 7 Brad54 Team Chevelle Cruiz-ins 0 Jun 1st, 14 11:42 PM
NE Georgia Swap Meet, May 10 Brad54 Team Chevelle Cruiz-ins 0 May 3rd, 14 2:31 AM
NE Georgia Swap Meet, December 1 Brad54 Team Chevelle Cruiz-ins 0 Nov 26th, 12 4:41 PM
