Oil Pan Fix - Chevelle Tech
El Caminos El Camino & Sprint
 5Likes
  • 2 Post By X-77keith
  • 1 Post By 70SSTHUMPER
  • 2 Post By 427elco
post #1 of 14 (permalink) Old Apr 20th, 19, 2:58 AM Thread Starter
Question Oil Pan Fix
I recently ruined my day having my floorjack slip into my oil pan and damaged the front shallow section under the crank. Now its banging.
Anyone know of a quick and easy fix to pull out the dent? Its about the diameter of a short stack pancake. I heard its possible to loosen the motor mounts and raise the motor enough to replace the pan. Its the frame that looks in the way.
I also thought of draining the oil and try to pull the dent with a body shop stud welder / puller
427elco is offline
post #2 of 14 (permalink) Old Apr 20th, 19, 6:09 AM
Re: Oil Pan Fix
No amount of minor loosening will allow a BBC pan to be removed with the engine in the car. The flex plate or flywheel gets in the way of getting enough clearance. You might try the stud welder/ puller idea.
oldcutlass is offline
post #3 of 14 (permalink) Old Apr 20th, 19, 6:23 AM
KEITH
If the dent doesn't have a very pronounced crease, you might get away with the stud puller. My concern would be the stud making a hole in the pan while pulling. Kinda hard to weld up a hole in the pan with oil dripping out. I would pull the engine.
X-77keith is offline
post #4 of 14 (permalink) Old Apr 20th, 19, 6:26 AM
Re: Oil Pan Fix
Yeah, Keith is right. Pull it to fix.
post #5 of 14 (permalink) Old Apr 20th, 19, 7:37 AM
Re: Oil Pan Fix
X2 It's the best way to fix it. I'd buy a new pan if money allowed.
If you lend someone $20, and never see that person again, it was probably worth it.
Molly's 70 is offline
post #6 of 14 (permalink) Old Apr 20th, 19, 8:03 AM
KEITH
I have had good luck with the pans that summit sells. No name on them, but solid pans.
427L88 and shovelrick like this.
post #7 of 14 (permalink) Old Apr 20th, 19, 10:38 AM
Re: Oil Pan Fix
I had the same problem with a 4.3 S-10 when installing new motor mounts, I used a stud gun but it took near 2 hours to achieve what was needed to clear the crank.
My 2 cents,Mike
M Zeigler is offline
post #8 of 14 (permalink) Old Apr 20th, 19, 12:25 PM
jerry
Re: Oil Pan Fix
Did this on a small block. Fabbed a 3/8" bent rod with a flattened end. Formed it into a hook and fished it through the drain plug bung and worked the dent out for the most part. You have to consider the clearance of the pickup also, it needs to be at least 1/4" off the pan.
cheveslakr is offline
post #9 of 14 (permalink) Old Apr 21st, 19, 3:12 PM
scott
Re: Oil Pan Fix
I did the same thing on a 454 oil pan in a Chevelle a couple of years ago. I used a stud gun, pulled out the dent, and repaired it in the exact same manner as if it were on any other sheet metal body panel on the exterior. I would only pull that engine as a last resort and not the first thing to do as some others have suggested. I had mine completely repaired with an undetectable repair in less time than it would have probably taken to change the oil pan if the engine was already out of the car. Even if you pull a hole with the stud gun, you call still weld up the hole(if you drain the oil first) and proceed on with the repair. If you currently have no oil leak and pull it just to eliminate your psychological feeling of " I don't want to half ass it" , then you have the possibility of it leaking at the sealing surface after you change it if you don't get something perfectly clean and aligned during the replacement". And if that happens, you get to pull it out AGAIN! If you do it my way, you can spend an hour or so to see if it will work, and at the most, all you have wasted only a little time if it doesn't. If you pull it, you risk damaging things, it leaking at the mounting surfaces, and at minimum, a full day if not two days work ....... .....Just my 2 cents.......... I would just hate to see you go through all of that work for something that may have a much easier solution. But if you are looking for an excuse to pull it out to do some improvements and/or cleaning and painting inside the engine compartment...........well that's different. Good luck with whichever path you take.
71 Chevelle SS 454 Convertible
70 El Camino SS 454 (current project)
Team Chevelle membership # 5470
scottmn1 is offline
post #10 of 14 (permalink) Old Apr 22nd, 19, 2:10 AM Thread Starter
Re: Oil Pan Fix
I don't think the drain plug access whole will fly. The ding is towards the front of the pan . I don't think between the crank and the windage tray is enough clearance to attack it that way. I will try to fire up the stud welder . If it gets too hot and I blow through, Im not so sure Im a good enough welder to seal a hole there
427elco is offline
post #11 of 14 (permalink) Old Apr 24th, 19, 4:13 PM
Re: Oil Pan Fix
I'd try the stud puller first - if it doesn't work out the way you want it - pull the engine. It may take several studs to work it out gently and to clear every thing inside. A pic may give us more to go on.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #12 of 14 (permalink) Old Apr 24th, 19, 10:29 PM
RonO.
Re: Oil Pan Fix
As long as there are no creases involved and simply a matter of popping/pulling out to clear crank:
Measure how wide the pan is and size puller for exact fit.
68-13427 likes this.
1970 Chevelle 517 cid, TH400, best ET mid 9's. #19.
70SSTHUMPER is offline
post #13 of 14 (permalink) Old May 2nd, 19, 2:11 AM Thread Starter
Re: Oil Pan Fix
Has a crease on the circumference of the ding . I just received a dent puller gun that uses epoxy hot glue. Will report on results later
427L88 and 68-13427 like this.
427elco is offline
post #14 of 14 (permalink) Old May 2nd, 19, 6:22 AM
Re: Oil Pan Fix
I really never considered a stud gun Like Dent Wizard Scott! . Hope it works Steve!
This Thread is more than 441 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Engineering Test Data on "High Mileage" Motor Oils 540 RAT Performance 26 Dec 9th, 15 8:13 PM
What weight oil do u use? lucky3 Performance 68 Jan 14th, 15 5:26 AM
FT cam users,info on SM/SN & latest GF5 oil vs FT Cam anti wear req SWHEATON Engine 45 May 31st, 14 11:31 PM
Lost a cam lobe and 2 lifters Scott MH Performance 44 May 31st, 13 11:59 PM
Interesting Oil Observations! rocks66ss Performance 55 Jan 17th, 13 8:27 PM
