1970 el camino fuel lines. - Chevelle Tech
El Caminos El Camino & Sprint
post #1 of 6 (permalink) Old Apr 13th, 19, 5:12 PM Thread Starter
darryl
I have the 1/4 and 3/8 fuel lines that need replacing. There is one section above the rear shock that has two near 90 degree bends. I get the idea theses lines were installed on the frame before the body was installed at the factory. Does anyone know how to replace these lines?
396driver is offline
post #2 of 6 (permalink) Old Apr 13th, 19, 5:34 PM
"Wild Bill"
Re: 1970 el camino fuel lines.
Gotta lift the body. Or, cut & splice that section
Wagon frame...same basic routing
Name:	1966 Wagon 012.jpg
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #3 of 6 (permalink) Old Apr 13th, 19, 8:18 PM Thread Starter
darryl
Thank you billscamino for that information. I needed confirmation of what I was thinking before cutting those shiny new fuel lines. I guess tomorrow I'll get it done.
post #4 of 6 (permalink) Old Apr 13th, 19, 9:03 PM Thread Starter
darryl
Hmm. I guess I should have asked, can I lift the body just enough on just that side, maybe 3/4s to get those lines in, or better to splice?
post #5 of 6 (permalink) Old Apr 13th, 19, 9:19 PM
You can lift the body in the rear but not with the front clip on it. If the dog house is off and you remove all the body mount bolts except for the front two, which need to be loosened, you can do it. There may be other considerations too such as steering shaft.
The biggest problem facing America today is that lies are so widely accepted as truths.
Alan F is offline
post #6 of 6 (permalink) Old Apr 13th, 19, 9:48 PM Thread Starter
darryl
Thanks Alan f. That sounds like a lot of work. I guess I'm splicing instead.
This Thread is more than 459 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Factory LS Fuel Lines on the Cheap pnugene LSx Engine 13 Apr 13th, 17 8:50 PM
Factory Fuel Lines & Gas Tank coldwaterdiver Restoration Corner 5 Oct 18th, 14 3:37 PM
fuel lines for an LT1 chevelle popbirch LSx Engine 12 Sep 18th, 14 4:14 PM
Concerning Fuel Delivery Systems Inquisitive Gearhead Performance 124 Apr 20th, 13 3:01 PM
Greetings from a "new" 1970 El Camino owner in Alameda mai tai New Member Introductions 4 Mar 8th, 13 5:34 PM
