Tailgate Hinge Repair - Chevelle Tech
El Caminos El Camino & Sprint
post #1 of 5 (permalink) Old Apr 4th, 19, 5:14 PM Thread Starter
I find that a previous owner (the king of short cuts) did a dubious repair of one tailgate hinge. He welded a nut on one side of the hinge and used a bolt from the other side. Since everything is fully painted I don't want to go too deep into repairing this if I can help it. I see they make hinge repair kits. I am assuming I can grind off the nut, drive out the bushing and put it back together. The other side is original and it looks like the pin is staked in. Is that correct. Does it need to be drilled out, or will it drive out, or do they have to be pressed out. If I am going to repair one, might as well do the other. Any advise or comments is welcomed.
55 Chevy Resto Mod - Sold
99 Corvette - Sold
68 El Camino - L79 Tribute
BobinPA is offline
post #2 of 5 (permalink) Old Apr 4th, 19, 7:00 PM
Re: Tailgate Hinge Repair
I will look at the spare hinges I have. I am in the process of putting one back together.
Robinls5 is offline
post #3 of 5 (permalink) Old Apr 4th, 19, 7:09 PM
Les
The pin will drive out. The repair kit comes with new pins and new brass bushings. It's an easy job - with the hinge removed. You should be able to save the paint if you are careful.
Les
65 El Camino (LS2 Project)
83 El Camino (DD)
04 Corvette Convertible
14 Cruze
Skylarkul is offline
post #4 of 5 (permalink) Old Jul 23rd, 19, 11:51 AM
Bryan
Hey guys, can you send me the info on where to buy the hinge repair kit? I need to do mine too.
Thanks so much
Griswold is offline
post #5 of 5 (permalink) Old Jul 24th, 19, 7:02 AM
Les
Thanks so much
Try here https://www.elcaminostore.com/catalo...tailgate+hinge
Les
83 El Camino (DD)
14 Cruze
Tailgate hinge pin on 69 el camino two69s Body Shop 3 Jul 29th, 17 9:24 AM
Fender and door gaps seem impossible BigBlock1969 Body Shop 8 Feb 1st, 15 11:37 AM
tailgate hinge rebuild dusterbd13 El Caminos 4 Oct 17th, 14 10:19 PM
"Basics of Basics" Hood spring installation or removal. MARTINSR Body Shop 34 Apr 29th, 14 9:55 PM
66 Chevelle Hood Alignment 66ChevelleMalibu Body Shop 5 Apr 14th, 14 9:10 PM
