Fuel gauge sender - Chevelle Tech
El Caminos El Camino & Sprint
 3Likes
  • 1 Post By bobm67
  • 1 Post By anix
  • 1 Post By oldcutlass
post #1 of 10 (permalink) Old Jan 7th, 19, 2:43 PM Thread Starter
Fuel gauge sender
Have any of you guys had to bend the arm on a new fuel sender. Mine is a 72 and I wanted to replace the unit because I thought it might be bad. But anyway mine should have a 0-90 ohm unit and I check the new one before I installed it and it was within an ohm or two of that. Problem is I can fill it up and it reads 3/4 tank so I went to the tank to take a reading on it and it only showed 60-65 ohms. So the float almost has to be hitting the top of the tank right???
BTW it was identical to the one I took out and my gauge is aftermarket and set for a 0-90 sender . Ordered as a direct replacement!!
Is it a common issue.
anix is offline
post #2 of 10 (permalink) Old Jan 7th, 19, 3:25 PM
bob
Re: Fuel gauge sender
I had to bend the float arm on the one that was in my car when I bought it. It was a 1/4 of a tank off.
bobm67 is offline
post #3 of 10 (permalink) Old Jan 7th, 19, 3:53 PM Thread Starter
Was yours off on the full side or empty side?
anix is offline
post #4 of 10 (permalink) Old Jan 7th, 19, 4:41 PM
Les
I have the opposite problem. My gauge registers full way too long and when it finally come off of full, the gauge goes toward empty like an express elevator. So, I'm assuming that the float arm is bent so that the float never actually reaches the top of the tank.
I haven't installed it yet but, here is going to be my solution. Floatless Fuel Sending Unit The gauge still won't 100% accurate as the fuel level, in the tank, drops, because the tank is mounted with the front lower than the back . Still, I'm hoping it will be more accurate than what I have now.
Les
65 El Camino (LS2 Project)
83 El Camino (DD)
04 Corvette Convertible
14 Cruze
Skylarkul is offline
post #5 of 10 (permalink) Old Jan 7th, 19, 5:13 PM Thread Starter
If it is the float arm I may try to bend it. I think I can flip the tank up side down and check it with a meter before I reinstall the tank but hey that is a good option. I can check the depth while I have it out so I know what to order. Thanks
anix is offline
post #6 of 10 (permalink) Old Jan 8th, 19, 6:42 AM
bob
Same as yours, didn't read full when the tank was full.
anix likes this.
bobm67 is offline
post #7 of 10 (permalink) Old Mar 4th, 19, 8:50 PM Thread Starter
Update..... Bent the arm now it reads right.
bobm67 likes this.
anix is offline
post #8 of 10 (permalink) Old Mar 4th, 19, 9:41 PM
When I read their fitment chart, all of the listings for the GM A bodies are for EFI tanks - I didn't see one for a factory tank. Unless I am missing something.
My Chevelle w/ open headers:
1971-Chevelle is online now
post #9 of 10 (permalink) Old Mar 4th, 19, 10:39 PM
I always put the new and old side by side to make sure they pivot the same distances. These gauges were never accurate just an approximation. The only 2 things you can tell accurately is when they are full or when they are empty, anything in between is just a guess. The way the tanks are mounted does not represent a symmetrical shape. Most gauges stay close to full for a long, time then drop slowly to half, and then quickly to empty.
Chevy 70 SS vert likes this.
oldcutlass is offline
post #10 of 10 (permalink) Old Mar 9th, 19, 7:43 AM
Les
Yes, you're right. I have the Tanks Inc. EFI tank. I don't think it matters whether it's a factory or EFI tank but, I'm assuming the mounting point on the tank would need to be close to horizontal so that the probe sits near vertical in the tank. The folks at Tanks Inc. could probably tell you - if you're interested.
Les
83 El Camino (DD)
14 Cruze
This Thread is more than 493 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
