Chevelle Tech - View Single Post - HID upgrade using BMW headlamps (long read)
post #19 of (permalink) Old Apr 18th, 13, 3:54 PM
70 nialator
Darren
Re: HID upgrade using BMW headlamps (long read)
The 2 pieces just sandwich the light in there like before with 2 of the 3 same mounting points. You will have to design a third for where the spring used to go. They set at exactly the same depth.
If you donít push the limits how are you going to find the weak spots?
USMC- Retired
My car: 1970 Chevelle
Factory 12 bolt /4-Speed Malibu -Dual stage wet nitrous with heater & purge - Holley Strip Dominator, Speed Demon 750 CFM - (All MSD distributor, blaster 3 coil, 6AL, & 3 stage retard) - 4 wheel disk brakes - Aeromotive Fuel system Ė Boss 338 18ís - BMW 5.25 true HID projector mod - and of course... the FLAPPER - bla, bla, bla.. lots of other expensive stuff I canít remember
70 nialator is offline
