Smoke start after shows - Chevelle Tech
 29Likes
post #1 of 66 (permalink) Old Jun 16th, 20, 4:21 PM Thread Starter
So here’s my recent issue. When I start the car after it sits many days, no issues at all. After I get to the cruise night, enjoy the show for a few hours and get ready to go home.
When I start the car, it cranks really good initially, but then seems to stumble and stop. Smoke comes up through the cowl induction door and I immediately start it to suck it all down. Runs fine going home. This has happened at the last 3 events.
Plugs have about 100 miles on them. Engine has 400 miles since 454 rebuild. I’m using Lunati 60203 Hydraulic cam with a Pertronix II and coil. Holley 3310 780 vacuum secondary carb
Stumped where to start?
Team Chevelle Member (20 years and counting...
72soft-top is offline
post #2 of 66 (permalink) Old Jun 16th, 20, 6:14 PM
Re: Smoke start after shows
Check for fluid leaks.
oldcutlass is offline
post #3 of 66 (permalink) Old Jun 16th, 20, 6:23 PM Thread Starter
Do you mean fuel leaks? Around Carb?
After it started on Sunday, I checked under the hood and didn’t see anything?
post #4 of 66 (permalink) Old Jun 16th, 20, 7:17 PM
Greg.
So the Engine does not have 500 Miles Breakin on it yet
Sounds to me like Unburnt Gas Fumes coming out of the Carb
Maybe running to Rich and Fuel left over in the Carb after driving to the Cruzin
Check the Spark Plugs now to see if they are wet/dark after a short drive
After 500 Miles Change Oil & Filter and Check Spark Plugs again
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #5 of 66 (permalink) Old Jun 16th, 20, 7:54 PM Thread Starter
Changed the oil and plugs at 300 miles. I’ll pull the plugs to see what they look like? I’ll also check float levels again. Maybe one is too high?
427L88 and Kirk's67SS like this.
post #6 of 66 (permalink) Old Jun 16th, 20, 9:34 PM
Levon
Check the torque on the intake bolts. May be loose after initial heat/cool cycling.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #7 of 66 (permalink) Old Jun 16th, 20, 9:36 PM Thread Starter
Thanks. I’ll do that
post #8 of 66 (permalink) Old Jun 16th, 20, 10:10 PM
Rame
What color is the smoke?
sampoerna415 is offline
post #9 of 66 (permalink) Old Jun 16th, 20, 10:31 PM Thread Starter
Blackish grey
post #10 of 66 (permalink) Old Jun 16th, 20, 11:02 PM
No, oil leaks, particularly on the exhaust.
post #11 of 66 (permalink) Old Jun 17th, 20, 12:01 AM
Rame
Tough one but my best guess would probably be fuel vapor lock issues, thinking when you turn off the car the fuel in the line from the pump boils and forces it's way into the intake and is causing a flooding issue, (probably why the issue goes away parked overnight). You might solve this problem by insulating you fuel line. Question: mechanical or electrical pump?
post #12 of 66 (permalink) Old Jun 17th, 20, 7:40 AM Thread Starter
I have a stock mechanical fuel pump. The fuel is custom bent using a brass Y block that is above the valve cover, so I think it’s probably a little cooler the stock routing.
post #13 of 66 (permalink) Old Jun 17th, 20, 1:50 PM
It sounds to me like the engine floods and gets choked off when started warm, then sucks the fuel vapors back into the engine when you re-start it. Almost certainly a carburetor/choke adjustment issue. You can lean out the choke on a Holley by loosening the three choke cover screws and rotating the housing clockwise.
Also, when starting a carbureted car cold, with an automatic choke (like yours, I see it in the photo) you press the accelerator pedal to the floor ONCE to provide a shot of fuel and set the choke. Car should fire right up immediately upon twisting the key.
On a warm engine, it should start without touching the accelerator pedal. If not, tap it lightly once while turning the starter over.
Also check your float levels, and you could possibly have a needle-and-seat issue.
427L88, guitargeak99 and 1966Chev like this.
69 Chevelle 496/TH400
ET/Speed - 11.371 @ 117.23 - SOLD JUNE 2017
1965 Chevy Impala 355/TH350 - NEW RIDE JUNE 2017
Georgia69 is offline
post #14 of 66 (permalink) Old Jun 17th, 20, 1:54 PM
Also, just looking at your engine photo, I see a wire going to the 12v terminal on your choke, but it's really hard to see if you have a ground wire on the other terminal? You definitely MUST have a ground wire for the choke to function properly. You probably have one and I just can't see it.
post #15 of 66 (permalink) Old Jun 17th, 20, 1:58 PM
Talking Re: Smoke start after shows
Simple, just don't go to shows.
Kirk's67SS and 70SSTHUMPER like this.
