Carb adjustment after ignition advance - Chevelle Tech
 17Likes
post #1 of 36 (permalink) Old May 28th, 20, 5:54 AM Thread Starter
Juan Ma
Hello everyone!
I have been doing adjustments on my 454 engine because the idle was unstable when hot.I have a Quick Fuel BR-67213 BRAWLER 750 CFM MECHANICAL SECONDARY. I have been reading a lot about it, but I have several questions. This is the way that I have used to adjust ignition advance and carb.
1. I set the ignition advance on 8 degrees. Most of the post said that 8-12 it's enough for a stock engine, but I don't know how is the correct ignition advance for me.
2. I turn off the engine. I set the mixture on carb, one and a half out from the bottom.
Engine doesn't start.
I have to set all mixture screws only half turn from the bottom. I think that only half turn it's no enough for a big block, isn't it?
Other way to start is setting idle high. By this way the vacuum value is over 20 PSI. I don't know when it supposes that I have to check highest vacuum.
3. Engine running and warm. With 8 degrees I have to use only half turn on all screws mixture. If I want to set one complete turn I have to set 12 to 16 degrees in order to get the highest vacuum value.
Why this happens??
Should I set again the ignition advance at this point?
4. Most of the times, if I set all the mixture screws the same amount the vacuum goes down. Where I should to start? Primary or secondary mixture screws?
In a nutshell, I don't know the order to set a perfect adjustment for ignition advance + carb.
kanij0 is offline
post #2 of 36 (permalink) Old May 28th, 20, 7:37 AM
Re: Carb adjustment after ignition advance
Disconnect the vacuum advance and leave it that way.
Keep adding initial timing until its either hard to start or pings at full throttle.
If 9.5:1 compression or lower use 87 octane if 10:1 or higher use 93.
Use a 180 thermostat.. If you have heating issues try a 160 thermostat. I find my motors run best with the 180..
I have a very low mileage stock 1978 454 low compression truck motor with 781 heads. My motor likes 20 degrees initial with 16 mechanical all in by 2500 rpm.. You want your timing to be fully advanced at cruising rpm at 35 mph..
hydro462 is offline
post #3 of 36 (permalink) Old May 28th, 20, 8:09 AM
What distributor are you running?
oldcutlass is offline
post #4 of 36 (permalink) Old May 28th, 20, 9:07 AM Thread Starter
Juan Ma
I have disconnected the vacuum advance and plugged with a screw.
I don't know the compression ratio and here, in Spain only have 95 and 98.
How could I know the perfect ignition advance for street?
Hei Stock distributor
ID:	628148   Click image for larger version
hydro462 likes this.
kanij0 is offline
post #5 of 36 (permalink) Old May 28th, 20, 10:01 AM
mark
why does that wiring look wrong to me???
aimhard likes this.
1965 malibu,03 silverado ss
M.J. 496
th350,4.11 3250lbs,+185 FOR ME
28x10.5 Hoosiers
9.85,135.50,1.35
mino65 is offline
post #6 of 36 (permalink) Old May 28th, 20, 10:04 AM
Bart
Do this first and you will find it a WHOLE lot easier to get it running right....
Bart_Swisher is offline
post #7 of 36 (permalink) Old May 28th, 20, 10:12 AM
I hope those numbers on the cap arent for the cylinders...
72 SS 402/4 speed/Straub roller and a bunch of Duramaxes.....
jrkrace is offline
post #8 of 36 (permalink) Old May 28th, 20, 11:37 AM Thread Starter
Juan Ma
No. They aren't for cylinders, don't worry about it
kanij0 is offline
post #9 of 36 (permalink) Old May 28th, 20, 5:09 PM
"Disconnect the vacuum advance and leave it that way."
"Keep adding initial timing until its either hard to start or pings at full throttle."
Just when will the flood of extreme misinformation from this one poster come to an end? It is dead wrong.
Georgia69, LeoP, caminonut and 1 others like this.
Dave Ray is offline
post #10 of 36 (permalink) Old May 28th, 20, 11:08 PM
What year vehicle is this in? Just curious if you have a full 12 volts to your distributor. If you're using a factory resistor wire for points ignition to that HEI, it's not going to run correctly.
Johnny Bravo is offline
post #11 of 36 (permalink) Old May 29th, 20, 9:13 AM Thread Starter
Juan Ma
The vacuum is disconnected and sealed. I add ignition advance until idle goes rough but, my doubt:
With 8 degrees and half turn on the mixture screws idles goes fine, with 16 degrees and one complete turn on mixture screws seems good too. What it's better?
Is normal only half turn on mixture screws?? Instructions sheet said that to must one and a half turn at first, then do adjustments.
At the distributor coil goes 12v, direct from battery, with a anti-thief switch. Should I replace it for another? For instance, electronic msd distributor?
kanij0 is offline
post #12 of 36 (permalink) Old May 29th, 20, 10:04 AM
Do this if you want your car to run like crap. Otherwise, disregard.....
71350SS and suprdave1 like this.
69 Chevelle 496/TH400
ET/Speed - 11.371 @ 117.23 - SOLD JUNE 2017
1965 Chevy Impala 355/TH350 - NEW RIDE JUNE 2017
Georgia69 is offline
post #13 of 36 (permalink) Old May 29th, 20, 10:30 AM Thread Starter
Juan Ma
I disconnected it only for adding ignition advance, after that I plug it again in the distributor vacuum advance
kanij0 is offline
post #14 of 36 (permalink) Old May 29th, 20, 11:12 AM Thread Starter
Juan Ma
Would it be a good improvement a electronic Ignition Distributor Coil ready to run??
Something like that? An electronic distributor without ignition box.
kanij0 is offline
post #15 of 36 (permalink) Old May 29th, 20, 11:17 AM
We don't know much about your engine (what camshaft you have, for example) but I've used fancy ignition systems in the past and honestly I think a GM HEI is the best. It looks like this is what you have already from the photos.
