Bronze Or Hardened Distributer Gear ? - Chevelle Tech
 3Likes
  • 2 Post By BillK
  • 1 Post By Dave Ray
post #1 of 8 (permalink) Old Mar 15th, 20, 5:48 PM Thread Starter
One source says hardened steel is OK w/all cams, another source says billet cams need bronze ?
Reelysalty is offline
post #2 of 8 (permalink) Old Mar 15th, 20, 7:10 PM
Vince
Re: Bronze Or Hardened Distributer Gear ?
need more info on your application;
what type of cam?
what type of oil pump ?
these impact the gear selection...
is a composite gear an option also??
VinceS427bb is offline
post #3 of 8 (permalink) Old Mar 15th, 20, 8:25 PM Thread Starter
These are blanket statements made by Summit Racing and Pertronics.
No qualifiers.
post #4 of 8 (permalink) Old Mar 16th, 20, 6:57 AM
Mr Bill
No qualifiers.
And you trust them ???? The only one I would trust for the correct answer would be the camshaft manufacturer for the actual camshaft you are using. Period.
LeoP and 72LS3Z27 like this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #5 of 8 (permalink) Old Mar 16th, 20, 4:52 PM
Who's and what cam?
'67 Malibu,468 w/TH400
Project-
72LS3Z27 is offline
post #6 of 8 (permalink) Old Mar 16th, 20, 8:03 PM
I'm with BillK, ASK THE CAM MANUFACTURER DUDE.
Only other thing, I have seen more composite gears frag apart than one can imagine, use with a lot of care, make sure it has a warrantee.
Dave Ray is offline
post #7 of 8 (permalink) Old Apr 8th, 20, 8:21 AM
use a lunati everwear gear with a billet cam gear if that helps
those composites do a lot of damage when they let go...tried a bronze
Maybe ok for a track car but on the st fills the crankcase up wiht a lot of dust didnt care for it
Ask your cam grinder to use a different gear other than billet
cuisinartvette is offline
post #8 of 8 (permalink) Old Apr 8th, 20, 4:43 PM
Bronze is a sacrificial gear for billet steel cams, the gear may live 5k on the street, and is designed to wear away before doing damage to the billit cam.
Hydraulic roller vcams use a regular type cam gear coted with a "Melonized" coating for break in, and stock GM hyd roller cams are industrial hard chromed from the factory.
The new disaster composite cam gears are supposedly for other than cast cams, to help with increased mileage, before they need replacement. I see a lot of these, absolutely done in in less than 4K miles.
Plastic gears are useless, 10K and they are work heated enough to crack and fail. My Plymouth 225 Slant 6 went through these stock plastic gears right on target, 5K miles, cracked, split, done in.
There are also both hardenable, and hardened cams available, they require different gears as well.
ASK CHRIS STRAUB HERE ON THE BOARDS.
LeoP likes this.
Dave Ray is offline
