HEI Module any difference in SB and BB - Chevelle Tech
 2Likes
post #1 of 20 (permalink) Old Dec 9th, 19, 2:33 PM Thread Starter
Is there a difference or does all the 4 pin modules fit all models. I have a 454 and put one that was for a 350 and the car actually runs worse.
Slick87gn is offline
post #2 of 20 (permalink) Old Dec 9th, 19, 4:15 PM
Randy
Re: HEI Module any difference in SB and BB
They're the same.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #3 of 20 (permalink) Old Dec 9th, 19, 5:53 PM
Not only that the distributors are the same. The only thing that changes are the weights and center plates for stock ones.
oldcutlass is offline
post #4 of 20 (permalink) Old Dec 9th, 19, 6:15 PM
Was the one you took from the 350 a GM module?
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #5 of 20 (permalink) Old Dec 9th, 19, 9:44 PM Thread Starter
No got it from Autozone. Their brand. Had to raise the idle and the temp went up a lot. I actually think its defective.
post #6 of 20 (permalink) Old Dec 9th, 19, 9:48 PM
Randy
Sounds like your timing is a little retarded, did you check it after installing the new module?
77 cruiser likes this.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #7 of 20 (permalink) Old Dec 9th, 19, 10:57 PM
x2, recheck your timing.
post #8 of 20 (permalink) Old Dec 10th, 19, 2:44 AM Thread Starter
Module controls timing ??
post #9 of 20 (permalink) Old Dec 10th, 19, 3:24 AM
Module controls dwell which controls timing.
post #10 of 20 (permalink) Old Dec 10th, 19, 9:48 AM Thread Starter
Took your advice. Timing mark no where near the tab almost at the 12 oclock position. Can a module make that drastic of a change ? She was running fairly decent before. wasn't running hot till this module change. Guess i'll pick up a name brand this time
post #11 of 20 (permalink) Old Dec 10th, 19, 10:28 AM
Is it running better now? Yes, a module change can cause a change in timing.
post #12 of 20 (permalink) Old Dec 10th, 19, 11:07 AM Thread Starter
Ordered one from Rockauto with a few other items. Real strange that the mark will move all the way up to 12 o'clock. Cam and timing chain less than 500 miles. Lunatti Voodoo
post #13 of 20 (permalink) Old Dec 10th, 19, 11:34 AM
Dwell and timing are two different things.
The four terminal module adjusts the starting point of dwell to compensate for RPM and battery voltage, but the end of dwell (the ignition point) always stays the same (ie: when the reluctor wheel teeth passes by the pickup coil teeth).
69ZL1 is offline
post #14 of 20 (permalink) Old Dec 11th, 19, 7:44 AM Thread Starter
Question. If vehicle was timed 18 degrees before TDC and ran great. then all of a sudden it ran like crap. Decided to change module and now timing mark at idle was in the 12 o clock position the only thing I can figure is the balancer slipped.
post #15 of 20 (permalink) Old Dec 11th, 19, 7:52 AM
Distributor could have been loose and simply moved on you. Timing chain could have jumped a tooth (or more), distributor gear could have jumped a tooth (or more.)
Sounds like the module is not the problem from your description. To summarize what I read - it was running good with old module, then suddenly running bad with old module, switched module, still running bad, checked timing, timing way off.
I would pull the distributor and look for any funny business at the cam/distributor gear first.
lucifershammer is online now
