Question for David Ray - Chevelle Tech
 14Likes
  • 2 Post By Dave Ray
  • 1 Post By toofastforyou
  • 3 Post By boyd66k20
  • 2 Post By 427L88
  • 6 Post By Tommy the Cat
post #1 of 15 (permalink) Old Nov 22nd, 19, 10:30 PM Thread Starter
I was told that retarding timing in high gear is supposed to help performance. I was wondering if you could enlighten me on this one, as I am going to put in the MSD timing dial back on the car but what to look for when you retard the timing other than for running NOS.
68Chevele is offline
post #2 of 15 (permalink) Old Nov 23rd, 19, 9:02 PM
Re: Question for David Ray
I have decided to lay a bit back on answering questions for a while, I have a real fight to et my hand rehab so I can go back to work.
The last few days have shown even more attacks from a few prsons here on the board against me, and nobody, including me, needs any of that. I am well aware no matter what I post, especially the way things automotive, and ignition related really works, the attacks will continue, without let up.
This is a hobby for a lot of board members, not a "I'm gonna attack Dave, so I can be a hero" contest. I don't care to feed those few person's ego's.
Respectfully, '68, sorry to be this way, but, it is the way it has to be.
A hero will be right along to attack me, and confuse everyone else.......shortly.
Eddie K and 68Chevele like this.
Dave Ray is offline
post #3 of 15 (permalink) Old Nov 24th, 19, 12:09 AM
I'll answer your question, whoever told you that is wrong. At cruise-highway speed, light throttle, and in high gear, timing is advanced through the vacuum canister to give the lean fuel mixture time to burn completely. With that said, without a vacuum cannister and depending on what rpm your cruising at, the amount of distributor mechanical advance is based on how your timing curve is set up. Retarding the timing will not result in more power and will require more throttle to maintain speed. With NOS its all about combustion time so the timing needs to be retarted.
oldcutlass is online now
post #4 of 15 (permalink) Old Nov 24th, 19, 7:15 PM
I think he might be talking about WOT.
https://www.chevelles.com/forums/374...ng-retard.html
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is online now
post #5 of 15 (permalink) Old Nov 24th, 19, 9:36 PM
Lance
FWIW....back in the heyday of Junior Stockers it was fashionable to use extra timing in 1st and 2nd gears of a 3 speed trans / or 1st,2nd and 3rd gears of a 4 speed to gain starting line advantage and when the shift was made to high gear the ignition would be retarded so it would pull in high gear. Some did this with dual point distributors with different dwell settings on each set of points then switching to 1 set of points in high gear (retarded), I also heard some used a cable thru the firewall hooked up to the points plate that was pulled back in high gear to retard the advance 2-4 degrees, never actually saw one of these set ups. Today its all done electronically, best example might be those who run over 100-125 HP, and up, nitrous kits. Keeps the rings and pistons from melting. Look at nitrous retard kits or special chips for this purpose.
vortec710 is offline
post #6 of 15 (permalink) Old Nov 24th, 19, 9:53 PM
Claude
Back in the 80's when I was racing a '67 Camaro in the NHRA Super Stock classes, I used an MSD retard timing module in which there was a "degree" chip activated by a switch. The chip I was using had 10° of timing so when I was launching the car, I had 38° degrees in of timing in 1st gear and when shifting in 2nd gear, I flipped the switch to remove 10° degrees giving me 28° degrees total in 2nd and 3rd gears. Worked great!
Claude.
P.S: This was for a race-only car… I'm not sure there would be some benefits using this on a street vehicle…
68Chevele likes this.
1971 Chevelle SS
toofastforyou is offline
post #7 of 15 (permalink) Old Nov 25th, 19, 8:40 AM
Hey Dave, Sure hope your hand gets back to working as it should and hope you reconsider, as there are guys here that don't have your vast knowledge and like to hear what you have to teach. It's a learning cure for me anyway and any knowledge that you add is beneficial.
Nothing worse than when life throws you a curve ball (spider bite) , and you have to make the adjustments.
Best Boyd
VinceS427bb, p40 and BigBlockLover like this.
USN-SSBN 645-G
boyd66k20 is offline
post #8 of 15 (permalink) Old Nov 25th, 19, 8:58 AM
Be well Dave. The physical crap you are enduring aint for sissies that's for sure.
LeoP and VinceS427bb like this.
post #9 of 15 (permalink) Old Nov 25th, 19, 11:44 AM
Dave, there's plenty of us here that respect and appreciate what you have done and continue to do for the community.
And look at the attacks as a sign that you have accomplished something. Nobody attacks the stable boy, they go after the king. There's no glory in firing a shot at someone who hasn't put a squirt of piss in the bucket but it takes at least false bravado to come after a guy who has as many pelts on the wall as you do.
Get your hand better, friend.
427L88, LeoP, VinceS427bb and 3 others like this.
70 Camino...Roller
Tommy the Cat is offline
post #10 of 15 (permalink) Old Nov 25th, 19, 10:28 PM
Well said..
67ss4spd is offline
post #11 of 15 (permalink) Old Nov 26th, 19, 8:12 PM Thread Starter
That's cool, I totally understand, I especially know how people can get as I run our website.
post #12 of 15 (permalink) Old Nov 26th, 19, 8:15 PM Thread Starter
Claude.
Did the car pick up anything performance wise in testing?
post #13 of 15 (permalink) Old Dec 3rd, 19, 1:37 AM
Hi Dave,
Get well soon. Story for you...about two years ago I was hanging with a couple of buddies. Neither of them are on this site. We got into the manifold versus ported timing debate. At the time my 67 wasn't running well. Both of these guys are in the ported camp. I've run manifold vac advance on this thing for years. It goes back and forth with both of these guys talking about all the magazines say and so on. One of them grew up in Anderson, IN and after a bit I said something like "Dave Ray says....manifold vacuum" and he got quiet. (Turned out it was a bad cap and rotor.)
Zeke
67 Chevelle
64 Chevelle
90 Corvette ZR1
TC# 3094 ACES# 7297
zeke67 is offline
post #14 of 15 (permalink) Old Dec 3rd, 19, 4:40 AM
Gary
This was on a fast top sportsman car but a guy told me the car ran more mph when they added more timing towards the end of the run. My thinking was a lot less load on the engine towards the top end if the track
gnicholson is offline
post #15 of 15 (permalink) Old Dec 3rd, 19, 5:57 AM
Claude
I don't remember as this was more than 30 years ago.
Claude.
1971 Chevelle SS
