which coil mfr. to trust? - Page 2 - Chevelle Tech
 25Likes
post #16 of 51 (permalink) Old Sep 20th, 19, 7:10 PM
Banned
Cory
Re: which coil mfr. to trust?
I've read all your posts and I know more than you.
427L88 likes this.
dream66 is offline
post #17 of 51 (permalink) Old Sep 21st, 19, 5:56 AM
doesn't everybody know more than Dave?
427L88 likes this.
post #18 of 51 (permalink) Old Sep 21st, 19, 9:07 AM Thread Starter
Jay
Thanks for the posts. I need to gain a stronger understanding of the electrical system. In doing some reading, I realized that maybe I need to look at the various connections, too. The alternator may be an issue as well, but the wiring/connections probably need some attention. This article was helpful
https://www.onallcylinders.com/2015/...a-classic-car/
I bought a napa alternator (63 amp) because it's a gorgeous weekend and I really want to use the car, but if the connections are corroded/weak, I could still be in the same situation after replacing it. Thinking I'll return it and get a powermaster since I'm hesitant to move the car now. But the only thing I'm running that's an additional draw over factory is the HEI and stereo. Both have been in the car for years, and I can keep the stereo off.
jat70 is offline
post #19 of 51 (permalink) Old Sep 21st, 19, 10:12 AM
Like was said above, a weak alternator will not cause your hei module to fail. The coil will.
'71 chevelle, 468, TH400, 12 bolt posi w/3.08's, drinks a lot of 87 octane.
v8440 is offline
post #20 of 51 (permalink) Old Sep 21st, 19, 10:22 AM
I agree.
I also agree with Mr. Ray's assessment of MSD's belief that the alternator may be causing the module to fail-it's HILARIOUS.
It's not causing your ignition component failures.
That said, it's never a bad idea to have a better alternator.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #21 of 51 (permalink) Old Sep 21st, 19, 1:04 PM
Instead of the stock 63 ampere alternator, I'd have gone with the stock GM 94 ampere 3 wire internally regulated 12SI alternator. They literally bolt in place of the stocker, and can be "clocked" to get the wires aimed to clear stuff if needed. Simple jumper, as outlined above makes it work just like a single wire Power-Master, and the charge light can be connected, if you have one.
Then, there are the new fully electronic regulators available that change the remote regulator operation to that of what the internally regulated ones operate as. Wells VR715 comes to mind.
Dave Ray is offline
post #22 of 51 (permalink) Old Sep 22nd, 19, 7:39 AM Thread Starter
Jay
I didn't end up putting the alternator in because I tested the existing one and it's charging fine. 14.75 volts with nothing on. If I put the stereo and the headlights on, it drops to low 13's. Having just one or the other on, there's no significant change. I'm returning this one. If I do change it, I will get a higher amp one. Check some connections and replace the coil. Drove it around yesterday with the same coil and there was no issue. Do coils fail and then function fine again?
jat70 is offline
post #23 of 51 (permalink) Old Sep 22nd, 19, 8:38 AM
Like a starter, when hot the coils can expand and short. You know, like a bad starter is fine cold but on restart you have to wait a while.
jat70 likes this.
How may I help you?
1999 Trans Am-500hp
post #24 of 51 (permalink) Old Sep 22nd, 19, 12:55 PM
To add to Paul's fine post above, coils are not so funny stuff. they have minds of their own, and fail at any time, but, testing them should be done as they are going to their full operating temperatures, not cold. This is why old resistance values are not sufficient to get the entire coil health profiles, running them off the car on a dedicated test machine, getting them hot....ARE.
LeoP and jat70 like this.
Dave Ray is offline
post #25 of 51 (permalink) Old Sep 22nd, 19, 3:37 PM
Just yesterday I replaced the coil in the cap of my hei with a remote coil setup. I had already bought the stuff to do it, and it started acting oddly at idle and just off idle. It would knock once every now and then, like over advanced timing but only a single knock. I figured it was either failing plug wires arcing or the coil starting to fail. I went ahead and did the coil upgrade, problem gone. Yes, coils can start acting up and then stop for a while.
jat70 likes this.
v8440 is offline
post #26 of 51 (permalink) Old Sep 23rd, 19, 10:18 AM Thread Starter
Jay
For now, I'm ordering the 8401 MSD dust cover and the O'Reilly coil with a bracket. Do I need a resistor or anything else to convert to external coil?
jat70 is offline
post #27 of 51 (permalink) Old Sep 23rd, 19, 10:29 AM
Marcus
No resistor, but add the Hei low resistance bushing I linked on the first page.
https://www.chevelles.com/forums/11147716-post7.html
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #28 of 51 (permalink) Old Sep 23rd, 19, 11:05 AM
Also Jay, I bought a tool that unpacks the original spade terminals from their boots for a good cleaning. I did that 20 yrs ago, but still just replaced the "lighting" harness in the engine bay. It a handy little item for cleaning ALL connections, exe the bulkhead.
post #29 of 51 (permalink) Old Sep 23rd, 19, 12:51 PM Thread Starter
Jay
Is the one in the existing cap not usable for the conversion? I've read so much at this point I can't remember where I saw it, but I was under the impression I could use the one that's in there.
Thank you both!
jat70 is offline
post #30 of 51 (permalink) Old Sep 23rd, 19, 2:03 PM
.....I bought a tool that unpacks the original spade terminals from their boots for a good cleaning...
Sounds interesting. What is this tool?
How may I help you?
1999 Trans Am-500hp
